Permabanned
- 20 Apr 2011
- Suffolk
Hi guys
I have this pretty old mobo that I did buy from here a couple of months back before it went out of stock and was stopped selling.
I am running it with 4gb ddr2 800. The memory support lists states it can take:
Model Name: G41M-ES2L DDR2 1300 ( downgrade to DDR2 800 )
What does the downgrade to 800mhz mean? It will only run at that speed on this mobo?
Also it only lists the 1gb version by team. So does that mean I could only have 2gb max if I use 1300 ram? Link to mobo:
http://www.gigabyte.com/products/product-page.aspx?pid=3500#ov
So rather long story short, can I run the 1300 ddr2 with 2gb per stick to get back to 4gb? I want to overclock my Q6600 just past 3.0ghz and I am limited by the 800mhz ram I have right now.
If I need to change the mobo, does anyone have any ideas on a model to run a 775 chip that will support faster ram then 800?
Thanks for any help
Thanks for any help
