Memory for new E6600 system
30 Dec 2004
Looking to put together the following specs:
Intel Core 2 Duo E6600 "LGA775 Conroe" 2.40GHz (1066FSB)
BFG GeForce 8800 GTS OC2 640MB GDDR3 HDTV/Dual DVI (PCI-Express)
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK)
..but unsure which DDR2 memory is the best for this set up. I seen posted that the Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit is good but its only £81.00 which seems cheep as i've seen mem for over £200.
I'm not looking to OC but need the mem to be future prof so if i need to spend a bit to complement my new system so be it.
The Crucial Ballistix PC2-5300C3 would be fine or the PC2-6400C4 would also do, apparently they are the same memory, just spec'ed at different speeds.
I am using the PC2-6400C4 with the E6600. :)
I'd spend the other 30 quid and get the 8500s ...
I'm limited a bit in my overclocking with my Corsair 6400 - wish I'd bought higher-spec memory.
currently having to run it at 720MHz CAS5 (the RAM) -wheras if I had the Ballistix 8500 I could probably get away with 1070 .... :)
Mark
Their no need to buy 8500 memory. IMO
The Crucial 5300 should clock to 800MHZ 4-4-412 quite easily.
And if your not overclocking, i would actually go for a AMD system.
