Try both and see which you think is best, I think 1600mhz cas 9 will be better though given the 450mhz difference
So 4 clock ticks at 800mhz, or 8 clock ticks at 1600mhz will take exactly the same length of time. 9-9-9-24 @1600 is actually lower latency than 8-8-8-21@1332 , unless my math is out, you would need to have timings of 7-7-7@1332 to really have better latency than 9-9-9@1600
From the results of the benchmark posted above it looks like I will be better with setting my ram up to 1200mhz 7-7-7-20. Is that what I should have my RAM timings and frequency set to?
IMO the difference between the two would not be noticeable. if you are playing games you might notice a few frames extra. with my tinkering around I've found stability is key. Find what is most stable for you and keep that setting
There are some reviews out there which shows that 1600 gives you almost no real gain over 1333. Also, you'll need to check carefully that you mobo and cpu can handle 1600. I decided to just go for the 1333 as it was cheaper and will give me about the same perfomance. Better to spend the money on a better motherboard or cpu. Some great maths here though.![]()
