Memory help please
17 Jun 2009
I have a AMD2+ board which says supports DDR2 1066 DDR2 SDRAM with dual channel and says accommodates 2 unbuffered dimms upto 8gb per Dimm max size 16 GB but I cant seem to see which ones correspond to this and want to make sure i get some hald dcent compatable memory, Any suggestions on a decent one at a cheap price,
Thanks in advance, andy
ps cpu is phenom x3 8450
That's because there isn't any memory that corresponds to that - unfortunately, AM2+ boards only support two sticks of 1066 DDR2 and 2gb per stick is typically the maximum.
You can find larger capacities of memory than 2gb per stick but they are VERY VERY expensive!
