My spec:
AMD X2 4400+
ASUS ABR32-MVP Deluxe
Corsair XMS Xpert (2x512)
X1900XT-X
36GB RAPTOR x 2 (RAID Striping)
all this running on Windows XP Pro (64bit)
but I have huge HDD utilazation(caching) during gaming, and I can say in windows even.
I know I should have 2GB of ram, but I used to have this ram sticks and a single raptor on my old (ancient) spec without so intensive disk caching. Any ideas?
On the other hand I DO need to get 2GB cause atm is what causes my performance to be limited. The question is if I should add 2 more 512 sticks or replace it with 2x1GB sticks (and allow future upgrade to 4GB), but I havent got much time to read into dual cores. I know each core is supposed to use its own stack on each dimm. I see corsair cas2 as an option or maybe OCZ platinum (both on 3200 since I got AMD). Any ideas?
thanks.
AMD X2 4400+
X1900XT-X
thanks.
