hi i run a z370 tuf plus gaming board, 8700k, and 16gb gskill tridentz 4000mhz rated speed ram, i just cant get sorted with it, i have used xmp which for the most part is unstable, so i don't bother with xmp, so i set ram to 3200mhz stable, noticed today the voltage on the ram is 1.5v which i believe is considered to high because the boards auto voltage is to generous, i cannot find anywhere to adjust the voltage myself as there is a whole book on timings and voltages in bios, so i found oc tuner 1 and tried that, bios now says xmp 4000mhz enabled but with ram @3200 @1.35v (much better voltage) and also cpu slight enhancement, sorry but i am a bit lost with what is actually happening, is it on xmp but at best speed or something, if anybody can tell me in simple terms i would be very grateful thanks...
