Memory Speed?
9 Feb 2009
Essex
Hi Guys,
I recently built a new PC with some 4Gb OCZ DDR3 Platinum 1333Mhz (OCZ3P13334GK) memory and CPU-Z is reporting the following memory settings:
I understand that this memory runs at 1333Mhz 7-7-7-20 @ 1.8V
I've manually set the speed to 1333Mhz and the timings to 7-7-7-20 and the voltage to 1.8V in the BIOS but was wondering whether someone could tell me if this is all correct as it's showing as PC3-8500 (533Mhz)
I'm not too sure on memory so any reply is appreciated :D
The picture on the left is what your RAM is currently set at. The picture on the right is what your memory is capable of at different speeds. i.e. latency and voltage needed for each different speed.
