Memory stick suggestions/help
1 Aug 2008
UK
Hi, my colleagues at my workplace broke their old memory stick they use for tranferring files from a wondows pc to a pc running DOS, problem is not all memory sticks work on the DOS pc, as it not running windows and isn't hooked up to the internet to find drivers automatically as windows pcs tend to do.
So basically i was wondering if anyone knew a certain memory stick(s) that dont require drivers at all and/or can run on a DOS pc.
Cheers in advance for the help.
The Scop
