hi there,
currently running:
Motherboard Properties
Motherboard ID 64-0513-000001-00101111-102407Bearlake$0AAAA000_BIOS DATE: 10/24/07 21:06:54 VER: 5.13
Motherboard Name Asus Berkeley
Front Side Bus Properties
Bus Type Intel AGTL+
Bus Width 64-bit
Real Clock 267 MHz (QDR)
Effective Clock 1067 MHz
Bandwidth 8533 MB/s
Chipset Bus Properties
Bus Type Intel Direct Media Interface
Motherboard Manufacturer
Company Name ASUSTeK Computer Inc.
Product Information http://usa.asus.com/products1.aspx?l1=3
BIOS Download http://support.asus.com/download/download.aspx?SLanguage=en-us
Device Description
DIMM1: Samsung M3 78T2953EZ3-CE6
DIMM2: Samsung M3 78T6553EZS-CE6
DIMM3: Samsung M3 78T2953EZ3-CE6
DIMM4: Samsung M3 78T6553EZS-CE6
Field Value
Memory Module Properties
Module Name Samsung M3 78T2953EZ3-CE6
Serial Number 793246ECh (3964023417)
Manufacture Date Week 47 / 2007
Module Size 1 GB (2 ranks, 4 banks)
Module Type Unbuffered DIMM
Memory Type DDR2 SDRAM
Memory Speed DDR2-667 (333 MHz)
Module Width 64 bit
Module Voltage SSTL 1.8
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings
@ 333 MHz 5-5-5-15 (CL-RCD-RP-RAS) / 20-35-3-5-3-3 (RC-RFC-RRD-WR-WTR-RTP)
@ 266 MHz 4-4-4-12 (CL-RCD-RP-RAS) / 16-28-2-4-2-2 (RC-RFC-RRD-WR-WTR-RTP)
@ 200 MHz 3-3-3-9 (CL-RCD-RP-RAS) / 12-21-2-3-2-2 (RC-RFC-RRD-WR-WTR-RTP)
Memory Module Manufacturer
Company Name Samsung
Product Information http://www.samsung.com/Products/Semiconductor/DRAM/index.htm
North Bridge: Intel Bearlake G33
South Bridge: Intel 82801IR ICH9R
Field Value
North Bridge Properties
North Bridge Intel Bearlake G33
Intel Platform Salt Creek
Supported FSB Speeds FSB800, FSB1066, FSB1333
Supported Memory Types DDR2-667 SDRAM, DDR2-800 SDRAM, DDR3-800 SDRAM, DDR3-1066 SDRAM, DDR3-1333 SDRAM
Maximum Memory Amount 8 GB
Revision / Stepping 02 / A2
Core Voltage 1.25 V
In-Order Queue Depth 12
Integrated Graphics Controller
Graphics Controller Type Intel GMA 3100
Graphics Controller Status Disabled
PCI Express Controller
PCI-E 1.0 x16 port #2 In Use @ x16 (Asus EN8500GT Video Adapter)
Chipset Manufacturer
Company Name Intel Corporation
Product Information http://www.intel.com/products/chipsets
Driver Download http://support.intel.com/support/chipsets
Driver Update http://driveragent.com?ref=59
Field Value
CPU Properties
CPU Type QuadCore Intel Core 2 Quad Q6600, 2400 MHz (9 x 267)
CPU Alias Kentsfield
CPU Stepping G0
Instruction Set x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3
Original Clock 2400 MHz
Min / Max CPU Multiplier 6x / 9x
Engineering Sample No
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 2x 4 MB (On-Die, ASC, Full-Speed)
Multi CPU
Motherboard ID TEMPLATE ETEMPLATE
CPU #1 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 2399 MHz
CPU #2 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 2399 MHz
CPU #3 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 2399 MHz
CPU #4 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 2399 MHz
CPU Physical Info
Package Type 775 Contact LGA
Package Size 3.75 cm x 3.75 cm
Transistors 582 million
Process Technology 8M, 65 nm, CMOS, Cu, Low-K Inter-Layer, 2nd Gen Strained Si
Die Size 286 mm2
Core Voltage 1.275 V
I/O Voltage 1.275 V
Typical Power 130 W
Maximum Power 168.8 W
I am thinking to upgrade my ram from Ocuk, no overclocking, basically fastest ram my system can support and reliable too.planning to move to vista x64, so looking to buy 4-8 GB
What can you guys suggest me?
ta
currently running:
Bus Width 64-bit
Bandwidth 8533 MB/s
Device Description
Field Value
Module Width 64 bit
Memory Timings
Field Value
Core Voltage 1.25 V
Field Value
CPU Properties
CPU Stepping G0
Multi CPU
CPU Physical Info
Die Size 286 mm2
I/O Voltage 1.275 V
Typical Power 130 W
ta
