memtest errors
29 Oct 2002
Kent
Geil memtest errors
my new conroe system has been playing up since I built it, well rebuilt it as well twice and 3 new installations of windows.
Had 5 BSOD, page faults, but mainly Kernel32.dll errors. Some programmes when installed just wont load, Fear etc
running avp and kerio and thought it might be conflict problems etc
but just test ram memtest and it gave 18 errors in the first 1 minute lol, all of the order of values xxxxx do not match 3942760698 do not match 3942760666
What do I do now, stopped the test and then memtest crashed out to windows??
using orange slots on p5Wdh...2Gb Geil 6400 that Gibbo was harping on about ;)
Am
edit. Dont quite get memtest, told me to run two memtests each with 839 megs. Did this for 20 minutes and got 327 errors in 1 of the windows.
Now running it in 1 window for the last 10 minutes and no errors so far, says that 1617 couldnt be allocated... ok 606% 0 errors doing 1 test...
god im confused
That version of windows memtest is a bit crippled unless you pay for it. The trial version will only test a certain block of your RAM, and leave the rest untested, hence it only picking up errors some of the time.
You can either run multiple versions of it, or use memtest86+ a free memtest app that you have to put on a bootable floppy/cd.
You can either get it from:
http://www.memtest.org/
Or get it and a whole range of other apps on one cd (site also has great tutorials on how to make the cd) from:
http://www.ultimatebootcd.com/
Thats great cheers minstadave thanks for the reply - this is getting a real headache for me!
When running memtest I get a message that it will only test 800 or so meg of ram and the rest is unallocated (some 1600megs), so run two versions at the same time. When I run 1 version its fine, running two gives constant errors.
I have programs crashing all over the place lol, or failing. Was going to get my old crucial stuff out and test it in the new system, and try each stick seperately ext - its just a pain!
everything looks fine in cpu-z and the bios etc
Am
It sounds like dodgy memory, give memtest86+ a try, but it sounds like an RMA is in order if they're causing that much bother at stock settings.
leave mb with 1 stick in it, run memtest, make it run only test 5, c if it can pass 10 times, do the same with other stick, c if any faults. (quick way 2 find any early faults in ram )
if not run full test on 1 stick @ a time for about 5 hrs , then repeat with other ram stick.
any errors in this & u have faulty ram 99%
sure u not talking about prime 95 ?
He's talking about memtest for windows, the free version is crippled so you have to run multiple versions to test your whole memory.
One of the two processes was allocated the memory that is faulty.
ok rab will do. Yep running two win memtests gave lots of errors in one of them - word mismatch errors etc.
As a side note I ran prime full stress test, lasted 1 hour and 7 minutes until I got an error message failed to load temp something or other
ok, If the Ram is faulty and I RMA it - can I swop it for another and pay the difference? eg the gskills HZ might appeal more and a bit peed off at getting dodgy Geil etc :rolleyes:
am
edit. noticed this http://www.tiltedmill.com/forums/showthread.php?t=9660
I have kaspersky and hope this might be the problem - well hope but if it is can I get my 27quid money back for it lol!?
Geil memtest errors
Ok peeps ran all the tests. Geil PC2-6400.
Two sticks in orange slots. memtest gave 377 errors.
One stick in slot, gave 377 errors. Other stick in same slot 0 errors.
Seems I have a dodgy stick, the amount of trouble this has caused me in terms of setting up this system has been unreal!
so I presume I RMA and wait for another set - or change them to something more reliable - how would this work?
Am
;oh and Minstadave and rab - thanks for the help - much appreciated, the ultimateboot cd is worth its weight in gold :)
