RIG :
AMD 64 3200 Venice (@stock atm)
DFI Ultra-D (on default settings)
Corsair 2gb XMS kit (2.5-3-3-6)
ATI X1800XT pcie (@stock atm)
i did memtest just now because i am having boot problems with my pc
(a variation of the same problem with booting into windows or even at all, but usually 3 lights out of 4 are lit, which i believe to be memory?)
it went through from test 1-7 quite happily up to about 80% pass level, and then this happened;
can someone explain what this means..
ermmm, I would try setting the timings manually if I was you, try these for size.....
