Mercedes 2011 Car Launched
Man of Honour
29 Jun 2003
Wiltshire
http://www.f1fanatic.co.uk/2011/02/01/mercedes-w02-launch-first-pictures/
Looks great!
car looks fast ! im so excited for the first race now, theres suposed to be another version of the car we wont see until the last test aswell
Mercedes GP W02 Chassis
Construction: Moulded carbon fibre and honeycomb composite structure
Suspension: Wishbone and pushrod activated torsion springs and rockers
Dampers: Penske
Wheels: BBS forged magnesium
Tyres: Pirelli
Brakes: Brembo calipers
Brake discs/pads: Carbon/Carbon
Steering Power: assisted rack and pinion
Steering wheel: Carbon fibre construction
Electronics: FIA standard ECU and FIA homologated electronic and electrical system
Transmission
Gearbox: Seven speed unit with cast aluminium maincase
Gear selection: Sequential, semi-automatic, hydraulic activation
Clutch: Carbon plate
Dimensions
Overall length: 4800mm
Overall height: 950mm
Overall width: 1800mm
Engine
Type: Mercedes-Benz FO108Y
Capacity: 2.4 litres
Cylinders: 8
Maximum: rpm 18,000 (maximum FIA regulation)
Bank angle: 90°
Piston bore: 98mm (maximum FIA regulation)
Number of valves: 32
Weight: 95kg (minimum FIA regulation weight)
