That’s how much they are in the UK. £950? But why would you buy those? A rip-off is correct.
We charge roughly £250 for a double network drop run back to an existing patch panel. So for £1000 you could have 4 network drops, two of which could be ceiling mounted WLAN access points.
And, as someone pointed out, the fastest WLAN is a cable.
£200 - is that for 3 pack? If so, where did you see that?
The best price I have seen for the X50 3-pack is on Amazon as a pre-order for £290.
However, I have found the X60 3-pack for £249 which is very similar.
Just a heads up on the X60. I have these and tried using it as a router too but I had reliability issues with it. Stuck it in AP mode and got my Asus serving as a router again and no longer have any issues. Speed and coverage wise the X60 does perform really well, and I have ethernet backhaul for all units.
Thanks for the heads up.
Stupid question, but can I just switch off the wifi on Asus router and then just use the X60 for wifi?
Yes, it's how I have mine set up. Been running like this for a few months and no problems.
I have just upgraded to the newer Omada stuff (Went in whole hog to allow proper segregation of all my IoT Stuff) the EAP610/620HD's are actually really good, I connect at 900-1300mbps in most places and that's 3 times more than I need to max out my internet!
Wifi 5 or 6? Wifi 6. Not for the speed, but for the lower latency and how it handles multiple devices in a much better way.. I just upgraded to WiFi 6 of wireless streaming to the Oculus Quest 2 and it's been excellent with zero issues in bandwidth and stability..
Overall, the other option might be to look at the TP-Link Omada series. (entry enterprise level)
Like Ubiquiti, having more 'enterprise' grade APs tend to work more reliably, made for handling lots of connections and to provide good stability/uptime.
If just starting out, I'd recommend
OC200 Controller £50 - although if you have a raspberry Pi or a server you can install their controller software on, save £50 and just run it on your own hardware,
Then, I'd start with 2 EAPs, since they are larger units, they cover (IME) a larger area and having more is not always better, as they can conflict with each other..
EAP225 (AC1350) - £59ea
EAP245 (AC1750) - £87ea
EAP610HD (AX1800 Wifi 6) - £119ea
You can use them standalone and just login to each APs web ui, but the controller (like Unifi) is so slick and makes life so easy, it's worth running on a server or buying the OC200 as this will work if you ever upgrade your other network stuff to Omada compatible items (Great if you want VLANs and all that!)
I ran 3 x EAP225v1's running their free controller software on a Raspberry Pi for 3 years and it was flawless, never a single issue, great roaming and honestly never needed more, I only needed 2 APs for the house, the third was to get good coverage at the bottom of the garden!
I have just upgraded to the newer Omada stuff (Went in whole hog to allow proper segregation of all my IoT Stuff) the EAP610/620HD's are actually really good, I connect at 900-1300mbps in most places and that's 3 times more than I need to max out my internet! Wifi6 is much better from a latency point of view and offer all the better features to allow more devices to 'share' the bandwidth so probably worth spending more on those to start with!
Yes, you can walk around the house using deco M5s and it'll just stay connected.Makes sense, thanks.
Also currently, if I am using wifi calling on my iPhone, and when I move around the house from the airport extreme (AE) to the study, the call is dropped as it switches from AE to the router - all have the same SSID. So, I am thinking maybe I need 4 pack mesh system, so as to replace the wifi on the router. That way I should get no wifi dropout when using wifi calling - does that make sense?
Problem with those APs are similar to mine, despite a report of a 1.9-2.1 Gbps connection they are being fed by 1Gb ethernet so that is as fast as they'll go, I max out that Gb port on the AP with Wifi all the time, PITA, need better APs with 2.5G/10G ports.
Most of this years phones in the house have WiFi6 (e.g. Samsung S21U), my Quest2 has Wifi6, My Daughters new laptop (Yoga 9i) has Wifi6How are you measuring this? What clients do you have that are cable of >1Gbps wirelessly?
I'd recommend a set of Deco M5's. The M5's come with HomeCare (parental controls, QOS, virus scanning etc) for free. The newer models you have to pay a subscription for these features (called HomeShield).
I upgraded my main M5 to an X20 without knowing this, and ended up returning it. The features were much worse than what I've got on the M5s.
Bizarre how some TP-Link models come with HomeCare and some with HomeShield. Yes, looks like those are HomeCare which is the version you want.
I'm not sure you'll see an extra £200 in performance between those and the M5s, but they'll do the job. It's your money![]()
Not sure Wifi6 is going to future proof anything, it's still 5ghz. Once Wifi6e is mainstream the marketing will try to convince you that everything before it is obsolete.Probably not, but M5 is only Wifi 5 and the X60 is Wifi 6. As others have said Wifi 6 has lower latency and is better at handling multiple devices. i like to think it is slightly better at future-proofing...
