Hi
I am going to be purchasing a new build soon and have settled on a FD Meshify C as my case. The only concern I have is the front fan foam filter, which doesn't look removable from the metal mesh to get to the front side of it. How are you meant to remove the dust from the front of the foam? I am assuming the clips will snap if constantly used to remove. Is it washable?
