Hi guys, I just got a Meshify s2 to handle those components: 6800xt, 16gbram corsair vengeance pro rgb, i9 9900k (noctua nhd15-s) and an Aorus 2390 pro. I need an advice about my fans config: preinstalled the meshify comes with two 140 front intake and one rear for exhaust. I've added one corsair 140mm fan at the front and one bottom (intake). I've also two other spares corsair 140mm to fit inside, not sure If I'm good to go like this, or I should add someone to top exhaust. Consider that to the noctua cpu cooler I've added another noctua 140mm fans like in the normal nhd15 settings (two fans). THank you guys
