Hey,
I was having some problems with the internet before, and I needed to go into safemode to fix it. So I loaded up msconfig and ticked the box so it loads into safemode on next reboot, and low and behold it will not load into safe mode and the screen just stays blank. So I was kind of messed because I could not log into windows to disable safe mode!! I ran a repair installation using my repair disk, and that fixes it and I can go into safemode, but I get a message saying "the next part of setup cannot continue in safe mode, press ok to restart", so I am kind of messed up at the moment.
So if anyone can suggest anything (quicky if possible) I will greatly appreciate it.
Cheers,
Martyn
Cheers,
Martyn
