suarve said:Well been looking at swapping my 306 for an MG ZR (a grey, 3 dr 1.8 version) as they look cool as hell.
Can anyone link me up a reputable site that lists all the features for each model in this range.....
evo said:Checklist
* Engine: head gasket failure can cost thousands to repair. Signs include a wavering engine temperature gauge and 'mayonnaise' on the oil filler cap. Timing belts need replacing at 40,000 miles.
* Body: paint can scratch easily. Check for faults such as 'orange peel' and paint runs. Loose rear spoilers are common, and optional side skirts can work loose, too.
* Chassis: hard-driven cars suffer heavy tyre wear; replacements cost £100 each. Gear linkages can become slack, and clutch cables snap too frequently.
* Interior: loose trim, an ill-fitting glovebox and wobbly front seats are common, so ensure everything is tight and in place. Check radio and separate dash-top display match.
* Security: early cars lack a Category
1 alarm/immobiliser, while some insurance companies stipulate Tracker must be fitted. Central locking can be troublesome
suarve said:are there any major things i shopuld be looking out for?
TomO said:be careful not to buy a disguised rover 25/45/75![]()
cymatty said:Also i know people who have a 3yr old zr's that are rusting.![]()
My rover-bashing-thread-derailment-anticipation-sensor is going bezerkRich said:Or a rehashed Rover 200 from 10 years ago.....oh...wait....![]()
DannyDan said:My rover-bashing-thread-derailment-anticipation-sensor is going bezerk
