^^^ just talked about the above engine on MSN, anyone know the difference between that and an Mi16? just a different head/cam i suppose?
The Xantia will almost certainly have the iron blocked XU10J4 engine. Still a very good lump, just about 20kg heavier than the alloy block.
And 10 less horsepowers than the Mi16. A common problem with the Mi16 engine that the S16 and GTi6 engines are less prone to is oil surge around bends which is only really rectified by fitting a dry sump.
At this age most Mi lumps you'll find will need rebuilding before being put in so budget another k for that.
Hey,
Suppose here is the best place to ask.
How much power did the 1.9 in the 205 Gti produce and what was it to 60?
Why do people do the Mi16 conversion? Is it a matter of a huge power increase?
surely something like a windage tray would cure this without having to resort to more expensive solutions like a dry sump?They are very prone to oil surge in competition use.
You'd think so wouldn't you, but it appears not. Lots of people fit baffled sumps with no joy, they still get surge on long hard corners.surely something like a windage tray would cure this without having to resort to more expensive solutions like a dry sump?
The 1.9 is 130bhp, the Mi16 is around 160, which is a substantial increase in a car that weighs so little.
