I'll start with the usual "hope this is the right forum" bit as I couldn't see we have a general troubleshooting one on here.
My PC has this ongoing issue that I can only describe as micro-freezing, where the system just stops for a fraction of a second - no mouse movement, can't type etc. This comes on a fresh install of W11 - it was doing it during the install process so it leads me to think it's something hardware causing the problem.
Up until Friday evening, I was running W10 where the issue was worse - the system would either freeze entirely (display on screen but everything completely frozen) or cause the PC to reboot by itself. It's been going on for a while so I don't think it's the current heat that's the problem. As I'd decided to reinstall Windows, I figured I'd take the opportunity to go onto W11 - I've not had a full freeze or reboot, just the micro freezing.
Any ideas on where to look to solve the problem? Or any more information I can provide?
Temps are good at about 32C across all cores - huge case, plenty of air flow.
Ryzen 5 3600X @ stock
MSI B450 Tomahawk Max
16GB Patriot Viper Steel DDR4 3600 (2 x 8GB)
Sabrent Rocket M.2
Gigabyte RTX 3070 (Latest drivers)
Here's the output from CPU-Z
Thank you!
EDIT: Perhaps my PSU is something to investigate? A Corsair TX850 purchased in September 2009.
Sabrent Rocket M.2
Thank you!
| Processors | |
| CPU Groups | 1 |
| CPU Group 0 | 12 threads, mask=0xFFF |
| Number of sockets | 1 |
| Number of threads | 12 |
| APICs | |
| Socket 0 | |
| -- Node 0 | |
| -- CCD 0 | |
| -- CCX 0 | |
| -- Core 0 (ID 0) | |
| -- Thread 0 | 0 |
| -- Thread 1 | 1 |
| -- Core 1 (ID 1) | |
| -- Thread 2 | 2 |
| -- Thread 3 | 3 |
| -- Core 2 (ID 2) | |
| -- Thread 4 | 4 |
| -- Thread 5 | 5 |
| -- CCX 1 | |
| -- Core 3 (ID 4) | |
| -- Thread 6 | 8 |
| -- Thread 7 | 9 |
| -- Core 4 (ID 5) | |
| -- Thread 8 | 10 |
| -- Thread 9 | 11 |
| -- Core 5 (ID 6) | |
| -- Thread 10 | 12 |
| -- Thread 11 | 13 |
| Timers | |
| ACPI timer | 3.580 MHz |
| Perf timer | 10.000 MHz |
| Sys timer | 1.000 KHz |
| Processors Information | |
| Socket 1 | ID = 0 |
| Number of cores | 6 (max 6) |
| Number of threads | 12 (max 12) |
| Number of CCDs | 1 |
| Manufacturer | AuthenticAMD |
| Name | AMD Ryzen 5 3600X |
| Codename | Matisse |
| Specification | AMD Ryzen 5 3600X 6-Core Processor |
| Package | Socket AM4 (1331) |
| CPUID | F.1.0 |
| Extended CPUID | 17.71 |
| Core Stepping | MTS-B0 |
| Technology | 7 nm |
| TDP Limit | 95.0 Watts |
| Tjmax | 95.0 蚓 |
| Core Speed | 3599.2 MHz |
| Multiplier x Bus Speed | 36.0 x 100.0 MHz |
| Base frequency (cores) | 100.0 MHz |
| Base frequency (mem.) | 100.0 MHz |
| Instructions sets | MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA |
| Microcode Revision | 0x8701021 |
| L1 Data cache | 6 x 32 KB (8-way, 64-byte line) |
| L1 Instruction cache | 6 x 32 KB (8-way, 64-byte line) |
| L2 cache | 6 x 512 KB (8-way, 64-byte line) |
| L3 cache | 2 x 16 MB (16-way, 64-byte line) |
| Max CPUID level | 00000010h |
| Max CPUID ext. level | 80000020h |
| FID/VID Control | yes |
| # of P-States | 3 |
| P-State | FID 0x898 - VID 0x48 (38.00x - 1.100 V) |
| P-State | FID 0xA8C - VID 0x58 (28.00x - 1.000 V) |
| P-State | FID 0xC84 - VID 0x68 (22.00x - 0.900 V) |
| PStateReg | 0x80000000-0x49920898 |
| PStateReg | 0x80000000-0x47160A8C |
| PStateReg | 0x80000000-0x459A0C84 |
| PStateReg | 0x00000000-0x00000000 |
| Package Type | 0x2 |
| Model | 00 |
| String 1 | 0x0 |
| String 2 | 0x0 |
| Page | 0x0 |
| Power Unit | 0.0 |
| SMU Version | 46.67.00 |
| TDP/TJMAX | 0x5F005F |
| TCTL Offset | 0x0 |
| PMTV | 00240903 |
| Min Frequency | 550 MHz |
| Max Frequency | 4400 MHz |
| VID Limit | 1.4750 Volts |
| PBO Scalar | 1 |
| Package Power Tracking (PPT) | Current : 128.0 W, fused : 128.0 W |
| Thermal Design Current (TDC) | Current : 80.0 A, fused : 80.0 A |
| Electrical Design Current (EDC) | Current : 125.0 A, fused : 125.0 A |
| Temperature 0 | 32 degC (89 degF) (Package) |
| Temperature 1 | 30 degC (85 degF) (CCD #0) |
| Temperature 2 | 30 degC (85 degF) (Cores (Max)) |
| Temperature 3 | 29 degC (84 degF) (Core #0) |
| Temperature 4 | 30 degC (85 degF) (Core #1) |
| Temperature 5 | 29 degC (84 degF) (Core #2) |
| Temperature 6 | 28 degC (83 degF) (Core #3) |
| Temperature 7 | 29 degC (84 degF) (Core #4) |
| Temperature 8 | 28 degC (83 degF) (Core #5) |
| Temperature 9 | 29 degC (84 degF) (L3 Cache #0) |
| Temperature 10 | 29 degC (84 degF) (L3 Cache #1) |
| Temperature 11 | 31 degC (87 degF) (SoC) |
| Voltage 0 | 1.02 Volts (VID) |
| Voltage 1 | 1.03 Volts (CPU VDD) |
| Voltage 2 | 1.02 Volts (SoC VDD) |
| Power 00 | 21.97 W (Package) |
| Power 01 | 2.47 W (Cores) |
| Power 02 | 0.58 W (Core #0) |
| Power 03 | 0.68 W (Core #1) |
| Power 04 | 0.61 W (Core #2) |
| Power 05 | 0.11 W (Core #3) |
| Power 06 | 0.47 W (Core #4) |
| Power 07 | 0.03 W (Core #5) |
| Clock Speed 0 | 3599.16 MHz (Core #0) |
| Clock Speed 1 | 3599.16 MHz (Core #1) |
| Clock Speed 2 | 3599.16 MHz (Core #2) |
| Clock Speed 3 | 3599.16 MHz (Core #3) |
| Clock Speed 4 | 3599.16 MHz (Core #4) |
| Clock Speed 5 | 3599.16 MHz (Core #5) |
| Core 0 max ratio | (effective) 41.25 |
| Core 1 max ratio | (effective) 41.25 |
| Core 2 max ratio | (effective) 41.25 |
| Core 3 max ratio | (effective) 41.25 |
| Core 4 max ratio | (effective) 41.25 |
| Core 5 max ratio | (effective) 41.25 |
| Chipset | |
| Northbridge | AMD Ryzen SOC rev. 00 |
| Southbridge | AMD B450 rev. 51 |
| Bus Specification | PCI-Express 3.0 (8.0 GT/s) |
| Graphic Interface | PCI-Express 4.0 |
| PCI-E Link Width | x16 (max 16x) |
| PCI-E Link Speed | 2.5 GT/s (max 16.0 GT/s) |
| Memory Type | DDR4 |
| Memory Size | 16 GBytes |
| Channels | 2 x 64-bit |
| Memory Frequency | 1066.4 MHz (3:32) |
| Memory Max Frequency | 1600.0 MHz |
| CAS# latency (CL) | 15.0 |
| RAS# to CAS# delay (tRCD) | 15 |
| RAS# Precharge (tRP) | 15 |
| Cycle Time (tRAS) | 36 |
| Bank Cycle Time (tRC) | 51 |
| Command Rate (CR) | 1T |
| Uncore Frequency | 1066.4 MHz |
| Memory SPD | |
| DIMM # | 1 |
| SMBus address | 0x52 |
| Memory type | DDR4 |
| Module format | UDIMM |
| Module Manufacturer(ID) | Patriot Memory (7F7F7F7F7F020000000000000000) |
| SDRAM Manufacturer (ID) | SK Hynix (AD00000000000000000000000000) |
| Size | 8192 MBytes |
| Max bandwidth | DDR4-3602 (1801 MHz) |
| Max JEDEC | DDR4-2133 (1066 MHz) |
| Part number | 3600 C17 Series |
| Nominal Voltage | 1.20 Volts |
| EPP | no |
| XMP | yes, rev. 2.0 |
| AMP | no |
| EXPO | no |
| JEDEC timings table | CL-tRCD-tRP-tRAS-tRC @ frequency |
| JEDEC #1 | 10.0-10-10-25-35 @ 733 MHz |
| JEDEC #2 | 11.0-11-11-27-38 @ 800 MHz |
| JEDEC #3 | 12.0-13-13-30-42 @ 900 MHz |
| JEDEC #4 | 13.0-14-14-32-45 @ 966 MHz |
| JEDEC #5 | 14.0-14-14-35-49 @ 1033 MHz |
| JEDEC #6 | 15.0-15-15-36-50 @ 1066 MHz |
| JEDEC #7 | 16.0-15-15-36-50 @ 1066 MHz |
| XMP profile | XMP-3602 |
| Specification | DDR4-3602 |
| VDD Voltage | 1.350 Volts |
| Min Cycle time | 0.555 ns (1801 MHz) |
| Max CL | 17.0 |
| Min tRP | 10.55 ns |
| Min tRCD | 10.55 ns |
| Min tRAS | 21.61 ns |
| Min tRC | 37.74 ns |
| Min tRRD | 5.53 ns |
| XMP timings table | CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage) |
| XMP #1 | 9.0-11-11-21-36-n.a @ 953 MHz (1.350 Volts) |
| XMP #2 | 11.0-13-13-26-44-n.a @ 1165 MHz (1.350 Volts) |
| XMP #3 | 12.0-14-14-28-48-n.a @ 1271 MHz (1.350 Volts) |
| XMP #4 | 13.0-15-15-30-52-n.a @ 1377 MHz (1.350 Volts) |
| XMP #5 | 14.0-16-16-33-56-n.a @ 1483 MHz (1.350 Volts) |
| XMP #6 | 15.0-17-17-35-60-n.a @ 1589 MHz (1.350 Volts) |
| XMP #7 | 16.0-18-18-37-64-n.a @ 1695 MHz (1.350 Volts) |
| XMP #8 | 17.0-19-19-39-68-n.a @ 1801 MHz (1.350 Volts) |
| XMP #9 | 18.0-19-19-39-68-n.a @ 1801 MHz (1.350 Volts) |
| XMP #10 | 19.0-19-19-39-68-n.a @ 1801 MHz (1.350 Volts) |
| XMP #11 | 20.0-19-19-39-68-n.a @ 1801 MHz (1.350 Volts) |
| DIMM # | 2 |
| SMBus address | 0x53 |
| EPP | no |
| AMP | no |
| EXPO | no |
| Max CL | 17.0 |
| Monitoring | |
| Mainboard Model | B450 TOMAHAWK MAX (MS-7C02) (0x00000677 - 0x129436B4) |
| LPCIO | |
| LPCIO Vendor | Nuvoton |
| LPCIO Model | NCT6797 |
| LPCIO Vendor ID | 0x5CA3 |
| LPCIO Chip ID | 0xD4 |
| LPCIO Revision ID | 0x51 |
| Hardware Monitors | |
| Hardware monitor | Nuvoton NCT6796 |
| Voltage 8 | 1.14 Volts [0x8E] (CPU VCORE) |
| Voltage 9 | 1.22 Volts [0x4C] (DRAM) |
| Voltage 10 | 12.29 Volts [0x80] (+12V) |
| Voltage 11 | 5.12 Volts [0x80] (+5V) |
| Voltage 13 | 1.03 Volts [0x81] (NB/SoC) |
| Voltage 15 | 3.38 Volts [0xD3] (+3.3V) |
| Temperature 6 | 33 degC (91 degF) [0x21] (System) |
| Temperature 7 | 32 degC (89 degF) [0x20] (CPU) |
| Temperature 8 | 43 degC (109 degF) [0x2B] (PCH) |
| Temperature 10 | 36 degC (96 degF) [0x24] (MOS) |
| Fan 1 | 682 RPM [0x2AA] (CPU) |
| Fan 3 | 1018 RPM [0x3FA] (SYS fan 2) |
| Fan 4 | 956 RPM [0x3BC] (SYS fan 3) |
| Hardware monitor | AMD Ryzen Power Management |
| Temperature 0 | 29 degC (84 degF) [0x1D] (Core #0) |
| Temperature 0 | 30 degC (85 degF) [0x1D] (Core #1) |
| Temperature 0 | 29 degC (84 degF) [0x1D] (Core #2) |
| Temperature 0 | 28 degC (83 degF) [0x1C] (Core #3) |
| Temperature 0 | 29 degC (84 degF) [0x1D] (Core #4) |
| Temperature 0 | 28 degC (83 degF) [0x1C] (Core #5) |
| Temperature 0 | 29 degC (84 degF) [0x1D] (L3 Cache #0) |
| Temperature 0 | 29 degC (84 degF) [0x1D] (L3 Cache #1) |
| Temperature 0 | 31 degC (87 degF) [0x1E] (SoC) |
| Hardware monitor | NVIDIA NVML |
| Power 01 | 17.32 W (GPU) |
| Hardware monitor | NVIDIA NVAPI |
| Power 01 | 18.34 W (GPU) |
| Clock Speed 0 | 210.00 MHz [0xD2] (Graphics) |
| Clock Speed 1 | 405.00 MHz [0x195] (Memory) |
| Clock Speed 2 | n.a. (Processor) |
| PCI Devices | |
| Description | Host Bridge |
| Location | bus 0 (0x00), device 0 (0x00), function 0 (0x00) |
| Common header | |
| Vendor ID | 0x1022 (AMD) |
| Model ID | 0x1480 |
| Revision ID | 0x00 |
| PCI header | |
| Subvendor ID | 0x1462 (MSI) |
| Subsystem ID | 0x7C02 |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 1 (0x01), function 0 (0x00) |
| Common header | |
| Model ID | 0x1482 |
| PCI header | |
| Subvendor ID | 0x0000 |
| Subsystem ID | 0x0000 |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Description | PCI to PCI Bridge |
| Location | bus 0 (0x00), device 1 (0x01), function 1 (0x01) |
| Common header | |
| Model ID | 0x1483 |
| PCI header | |
| Primary bus | 0x00 |
| Secondary bus | 0x01 |
| Int. Line | 0xFF |
| Int. Pin | 0x00 |
| PCI capability | |
| Caps class | Power Management |
| Caps offset | 0x50 |
| Caps version | 1.2 |
| PCI capability | |
| Caps class | PCI Express |
| Caps offset | 0x58 |
| Device type | Root Port of PCI-E Root Complex |
| Port | 1 |
| Caps version | 2.0 |
| Physical slot | #0 |
| Presence detect | yes |
| Link width | 4x (max 4x) |
| Link speed | 8.0 GT/s (max 8.0 GT/s) |
| PCI capability | |
| Caps class | Message Signalled Interrupts |
| Caps offset | 0xA0 |
| PCI capability | |
| Caps class | Subsystem Vendor |
| Caps offset | 0xC0 |
| SubVendor ID | 0x1022 (AMD) |
| SubSystem ID | 0x1234 |
| PCI capability | |
| Caps class | HyperTransport |
| Caps offset | 0xC8 |
| Interface type | MSI Mapping |
| Location | bus 0 (0x00), device 1 (0x01), function 3 (0x03) |
| Common header | |
| Model ID | 0x1483 |
| PCI header | |
| Secondary bus | 0x03 |
| Int. Line | 0xFF |
| Int. Pin | 0x00 |
| PCI capability | |
| PCI capability | |
| Port | 0 |
| Link width | 4x (max 8x) |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Location | bus 0 (0x00), device 2 (0x02), function 0 (0x00) |
| Common header | |
| Model ID | 0x1482 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 3 (0x03), function 0 (0x00) |
| Common header | |
| Model ID | 0x1482 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 3 (0x03), function 1 (0x01) |
| Common header | |
| Model ID | 0x1483 |
| PCI header | |
| Secondary bus | 0x26 |
| Int. Line | 0xFF |
| Int. Pin | 0x00 |
| PCI capability | |
| PCI capability | |
| Port | 0 |
| Link width | 16x (max 16x) |
| Link speed | 2.5 GT/s (max 8.0 GT/s) |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Location | bus 0 (0x00), device 4 (0x04), function 0 (0x00) |
| Common header | |
| Model ID | 0x1482 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 5 (0x05), function 0 (0x00) |
| Common header | |
| Model ID | 0x1482 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 7 (0x07), function 0 (0x00) |
| Common header | |
| Model ID | 0x1482 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 7 (0x07), function 1 (0x01) |
| Common header | |
| Model ID | 0x1484 |
| PCI header | |
| Secondary bus | 0x27 |
| Int. Line | 0xFF |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| Port | 0 |
| Physical slot | Integrated device |
| Link speed | 16.0 GT/s (max 16.0 GT/s) |
| PCI capability | |
| PCI capability | |
| SubVendor ID | 0x7C02 |
| SubSystem ID | 0x1462 |
| PCI capability | |
| Location | bus 0 (0x00), device 8 (0x08), function 0 (0x00) |
| Common header | |
| Model ID | 0x1482 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 8 (0x08), function 1 (0x01) |
| Common header | |
| Model ID | 0x1484 |
| PCI header | |
| Secondary bus | 0x28 |
| Int. Line | 0xFF |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| Port | 0 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Description | SMBus Controller |
| Location | bus 0 (0x00), device 20 (0x14), function 0 (0x00) |
| Common header | |
| Model ID | 0x790B |
| Revision ID | 0x61 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Description | PCI to ISA Bridge |
| Location | bus 0 (0x00), device 20 (0x14), function 3 (0x03) |
| Common header | |
| Model ID | 0x790E |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 24 (0x18), function 0 (0x00) |
| Common header | |
| Model ID | 0x1440 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 24 (0x18), function 1 (0x01) |
| Common header | |
| Model ID | 0x1441 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 24 (0x18), function 2 (0x02) |
| Common header | |
| Model ID | 0x1442 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 24 (0x18), function 3 (0x03) |
| Common header | |
| Model ID | 0x1443 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 24 (0x18), function 4 (0x04) |
| Common header | |
| Model ID | 0x1444 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 24 (0x18), function 5 (0x05) |
| Common header | |
| Model ID | 0x1445 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 24 (0x18), function 6 (0x06) |
| Common header | |
| Model ID | 0x1446 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Location | bus 0 (0x00), device 24 (0x18), function 7 (0x07) |
| Common header | |
| Model ID | 0x1447 |
| PCI header | |
| Int. Line | 0x00 |
| Int. Pin | 0x00 |
| Description | NVM Express (NVMe) Controller |
| Location | bus 1 (0x01), device 0 (0x00), function 0 (0x00) |
| Common header | |
| Vendor ID | 0x1987 |
| Model ID | 0x5012 |
| Revision ID | 0x01 |
| PCI header | |
| Address 0 (memory) | 0x00000000FC700000 |
| Subvendor ID | 0x1987 |
| Subsystem ID | 0x5012 |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| Caps offset | 0x80 |
| Device type | PCI-E Endpoint Device |
| Port | 1 |
| PCI capability | |
| Caps class | MSI-X |
| Caps offset | 0xD0 |
| PCI capability | |
| Caps offset | 0xE0 |
| PCI capability | |
| Caps offset | 0xF8 |
| Description | USB Controller (xHCI) |
| Location | bus 3 (0x03), device 0 (0x00), function 0 (0x00) |
| Common header | |
| Model ID | 0x43D5 |
| PCI header | |
| Address 0 (memory) | 0x00000000FC6A0000 |
| Subvendor ID | 0x1B21 (ASMedia) |
| Subsystem ID | 0x1142 |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| Caps offset | 0x78 |
| PCI capability | |
| Device type | Legacy PCI-E Endpoint Device |
| Port | 0 |
| Description | Serial ATA Controller - AHCI |
| Location | bus 3 (0x03), device 0 (0x00), function 1 (0x01) |
| Common header | |
| Model ID | 0x43C8 |
| PCI header | |
| Address 5 (memory) | 0xFC680000 |
| Subsystem ID | 0x1062 |
| Int. Line | 0x00 |
| Int. Pin | 0x02 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Port | 0 |
| Location | bus 3 (0x03), device 0 (0x00), function 2 (0x02) |
| Common header | |
| Model ID | 0x43C6 |
| PCI header | |
| Primary bus | 0x03 |
| Secondary bus | 0x20 |
| Int. Line | 0x05 |
| Int. Pin | 0x03 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Device type | Upstream Port of PCI-E Switch |
| Port | 0 |
| PCI capability | |
| SubVendor ID | 0x1B21 (ASMedia) |
| SubSystem ID | 0x0201 |
| Location | bus 32 (0x20), device 0 (0x00), function 0 (0x00) |
| Common header | |
| Model ID | 0x43C7 |
| PCI header | |
| Primary bus | 0x20 |
| Secondary bus | 0x21 |
| Int. Line | 0x0B |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Device type | Downstream Port of PCI-E Switch |
| Port | 0 |
| Presence detect | no |
| Link width | 0x (max 1x) |
| Link speed | 2.5 GT/s (max 5.0 GT/s) |
| PCI capability | |
| SubSystem ID | 0x3306 |
| Location | bus 32 (0x20), device 1 (0x01), function 0 (0x00) |
| Common header | |
| Model ID | 0x43C7 |
| PCI header | |
| Secondary bus | 0x22 |
| Int. Line | 0x0A |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Port | 1 |
| Link width | 1x (max 1x) |
| PCI capability | |
| Location | bus 32 (0x20), device 4 (0x04), function 0 (0x00) |
| Common header | |
| Model ID | 0x43C7 |
| PCI header | |
| Secondary bus | 0x25 |
| Int. Line | 0x0B |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Port | 4 |
| Link width | 0x (max 4x) |
| PCI capability | |
| Description | Ethernet Controller |
| Location | bus 34 (0x22), device 0 (0x00), function 0 (0x00) |
| Common header | |
| Vendor ID | 0x10EC (Realtek) |
| Model ID | 0x8168 |
| Revision ID | 0x15 |
| PCI header | |
| Address 0 (port) | 0x0000F000 |
| Address 2 (memory) | 0x00000000FC504000 |
| Address 4 (memory) | 0x00000000FC500000 |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| Caps offset | 0x40 |
| PCI capability | |
| PCI capability | |
| Caps offset | 0x70 |
| Port | 0 |
| Link speed | 2.5 GT/s (max 2.5 GT/s) |
| PCI capability | |
| Caps offset | 0xB0 |
| Description | VGA Controller |
| Location | bus 38 (0x26), device 0 (0x00), function 0 (0x00) |
| Common header | |
| Vendor ID | 0x10DE (NVIDIA) |
| Model ID | 0x2484 |
| Revision ID | 0xA1 |
| PCI header | |
| Address 0 (memory) | 0xFB000000 |
| Address 1 (memory) | 0x00000000D0000000 |
| Address 3 (memory) | 0x00000000E0000000 |
| Address 5 (port) | 0x0000E000 |
| Subvendor ID | 0x1458 (GIGABYTE) |
| Subsystem ID | 0x404C |
| Int. Line | 0x00 |
| Int. Pin | 0x01 |
| PCI capability | |
| Caps offset | 0x60 |
| PCI capability | |
| Caps offset | 0x68 |
| PCI capability | |
| Port | 0 |
| Link speed | 2.5 GT/s (max 16.0 GT/s) |
| PCI capability | |
| Caps class | Vendor Dependant |
| Caps offset | 0xB4 |
| Description | High Definition Audio (HDA) |
| Location | bus 38 (0x26), device 0 (0x00), function 1 (0x01) |
| Common header | |
| Model ID | 0x228B |
| PCI header | |
| Address 0 (memory) | 0xFC080000 |
| Int. Line | 0x37 |
| Int. Pin | 0x02 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Port | 0 |
| Description | Non-Essential Instrumentation Device |
| Location | bus 39 (0x27), device 0 (0x00), function 0 (0x00) |
| Common header | |
| Model ID | 0x148A |
| PCI header | |
| Int. Line | 0xFF |
| Int. Pin | 0x00 |
| PCI capability | |
| Caps offset | 0x48 |
| PCI capability | |
| PCI capability | |
| Caps offset | 0x64 |
| Port | 0 |
| Location | bus 40 (0x28), device 0 (0x00), function 0 (0x00) |
| Common header | |
| Model ID | 0x1485 |
| PCI header | |
| Int. Line | 0xFF |
| Int. Pin | 0x00 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Port | 0 |
| Description | Encryption Device |
| Location | bus 40 (0x28), device 0 (0x00), function 1 (0x01) |
| Common header | |
| Model ID | 0x1486 |
| PCI header | |
| Address 2 (memory) | 0xFC300000 |
| Address 5 (memory) | 0xFC408000 |
| Int. Line | 0x05 |
| Int. Pin | 0x01 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Port | 0 |
| PCI capability | |
| PCI capability | |
| Location | bus 40 (0x28), device 0 (0x00), function 3 (0x03) |
| Common header | |
| Model ID | 0x149C |
| PCI header | |
| Address 0 (memory) | 0x00000000FC200000 |
| Int. Line | 0x00 |
| Int. Pin | 0x03 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Port | 0 |
| PCI capability | |
| PCI capability | |
| Location | bus 40 (0x28), device 0 (0x00), function 4 (0x04) |
| Common header | |
| Model ID | 0x1487 |
| PCI header | |
| Address 0 (memory) | 0xFC4F8000 |
| Subsystem ID | 0xEC02 |
| Int. Line | 0x24 |
| Int. Pin | 0x04 |
| PCI capability | |
| PCI capability | |
| PCI capability | |
| Port | 0 |
| PCI capability | |
| DMI | |
| SMBIOS Version | 2.8 |
| DMI BIOS | |
| vendor | American Megatrends International LLC. |
| version | 3.A0 |
| date | 02/03/2021 |
| ROM size | 16384 KB |
| DMI System Information | |
| manufacturer | Micro-Star International Co. Ltd |
| product | MS-7C02 |
| version | 1.0 |
| serial | To be filled by O.E.M. |
| UUID | {91A9128C-0896-3916-ACB5-00D861A65582} |
| SKU | To be filled by O.E.M. |
| family | To be filled by O.E.M. |
| DMI Baseboard | |
| vendor | Micro-Star International Co. Ltd |
| model | B450 TOMAHAWK MAX (MS-7C02) |
| revision | 1.0 |
| serial | J816706458 |
| DMI System Enclosure | |
| chassis type | Desktop |
| chassis serial | To be filled by O.E.M. |
| DMI Extension Slot | |
| designation | J6B2 |
| type | PCI Express |
| populated | yes |
| designation | J6B1 |
| populated | yes |
| designation | J6D1 |
| populated | yes |
| designation | J7B1 |
| populated | yes |
| designation | J8B4 |
| populated | yes |
| designation | J8D1 |
| populated | yes |
| designation | J8B3 |
| type | PCI |
| width | 32 bits |
| populated | yes |
| DMI OEM Strings | |
| string[0] | To be filled by O.E.M. |
| DMI Physical Memory Array | |
| location | Motherboard |
| usage | System Memory |
| correction | None |
| max capacity | 128 GB |
| max# of devices | 4 |
| DMI Processor | |
| manufacturer | Advanced Micro Devices Inc. |
| model | AMD Ryzen 5 3600X 6-Core Processor |
| clock speed | 3800.0 MHz |
| FSB speed | 100.0 MHz |
| multiplier | 38.0x |
| max clock speed | 4400.0 MHz |
| DMI data | |
| 000 | 0x04 0x30 0x17 0x00 0x01 0x03 0x6B 0x02 0x10 0x0F |
| 010 | 0x87 0x00 0xFF 0xFB 0x8B 0x17 0x03 0x8B 0x64 0x00 |
| 020 | 0x30 0x11 0xD8 0x0E 0x41 0x31 0x14 0x00 0x15 0x00 |
| 030 | 0x16 0x00 0x04 0x05 0x06 0x06 |
| DMI Memory Device | |
| designation | DIMM 0 |
| format | unknown |
| type | unknown |
| speed | 2133 MHz |
| manufacturer | Unknown |
| part number | Unknown |
| serial number | Unknown |
| manufacturer id | 0x3020 |
| product id | 0x5000 |
| DMI data | |
| 000 | 0x11 0x28 0x19 0x00 0x11 0x00 0x18 0x00 0xFF 0xFF |
| 010 | 0xFF 0xFF 0x00 0x00 0x02 0x00 0x01 0x02 0x02 0x04 |
| 020 | 0x00 0x55 0x08 0x03 0x04 0x00 0x05 0x00 0x00 0x00 |
| 030 | 0x00 0x00 0x55 0x08 0x00 0x00 0x00 0x00 0x00 0x00 |
| 040 | 0x44 0x49 0x4D 0x4D 0x20 0x30 0x00 0x50 0x30 0x20 |
| 050 | 0x43 0x48 0x41 0x4E 0x4E 0x45 0x4C 0x20 0x41 0x00 |
| 060 | 0x55 0x6E 0x6B 0x6E |
| designation | DIMM 1 |
| format | DIMM |
| type | DDR4 |
| total width | 64 bits |
| data width | 64 bits |
| size | 8 GB |
| speed | 2133 MHz |
| part number | 3600 C17 Series |
| serial number | 00000000 |
| voltage | 1.200000 |
| manufacturer id | 0x3120 |
| DMI data | |
| 000 | 0x11 0x28 0x1B 0x00 0x11 0x00 0x1A 0x00 0x40 0x00 |
| 010 | 0x40 0x00 0x00 0x20 0x09 0x00 0x01 0x02 0x1A 0x80 |
| 020 | 0x40 0x55 0x08 0x03 0x04 0x00 0x05 0x01 0x00 0x00 |
| 030 | 0x00 0x00 0x55 0x08 0xB0 0x04 0xB0 0x04 0xB0 0x04 |
| 040 | 0x44 0x49 0x4D 0x4D 0x20 0x31 0x00 0x50 0x30 0x20 |
| format | unknown |
| type | unknown |
| speed | 2133 MHz |
| DMI data | |
| 000 | 0x11 0x28 0x1E 0x00 0x11 0x00 0x1D 0x00 0xFF 0xFF |
| 050 | 0x43 0x48 0x41 0x4E 0x4E 0x45 0x4C 0x20 0x42 0x00 |
| format | DIMM |
| type | DDR4 |
| size | 8 GB |
| speed | 2133 MHz |
| DMI data | |
| 000 | 0x11 0x28 0x20 0x00 0x11 0x00 0x1F 0x00 0x40 0x00 |
| DMI Port Connector | |
| designation | J1500 (internal) |
| designation | USB 3.0 (external) |
| port type | USB |
| connector | Access Bus (USB) |
| designation | J1501 (internal) |
| port type | USB |
| designation | J1502 (internal) |
| designation | USB-C (external) |
| port type | USB |
| designation | J1503 (internal) |
| port type | USB |
| designation | J1504 (internal) |
| designation | USB 3.1 (external) |
| port type | USB |
| designation | Network (external) |
| port type | Network Port |
| connector | RJ-45 |
| designation | J1704 (internal) |
| designation | Sata Express (external) |
| designation | J1705 (internal) |
| designation | J1701 (internal) |
| designation | iSATA (external) |
| designation | J1702 (internal) |
| designation | J1703 (internal) |
| designation | J1706 (internal) |
| designation | J1100 (internal) |
| designation | HDMI (external) |
| port type | Video Port |
| designation | J1101 (internal) |
| designation | J1102 (internal) |
| designation | DP (external) |
| designation | J2100 (internal) |
| designation | Front Audio (external) |
| port type | Audio Port |
| connector | Mini Jack (headphones) |
| designation | J2101 (internal) |
| designation | Audio Jack (external) |
| designation | J1700 (internal) |
| designation | J10 |
| populated | yes |
| designation | J3600 Pcie x8 slot |
| populated | no |
| designation | J3707 Pcie x4 slot |
| designation | J3700 PCIE x4 slot from Promontory |
| populated | no |
| designation | J3702 PCIE x1 slot from Promontory |
| populated | no |
| designation | J3703 PCIE x1 slot from Promontory |
| populated | no |
| designation | J3701 M.2 WLAN/BT slot |
| populated | yes |
| Graphics | |
| Number of adapters | 1 |
| Graphic APIs | |
| API | D3D |
| API | NVIDIA I/O |
| API | NVIDIA NVML |
| API | NVIDIA NVAPI |
| pwrMask | 0x000C9CF3 |
| pwrTable | [F5 F6 00 00 FF FA FC E8 00 00 FE F6 F1 00 00 E0 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 ] |
| Display Adapters | |
| Display adapter 0 | |
| ID | 0x10B0104 |
| Name | NVIDIA GeForce RTX 3070 |
| Board Manufacturer | GIGABYTE Technology |
| Revision | A1 |
| Codename | GA104-300 |
| Core family | 0x174 (GA104-A) |
| Power Limit | 270.0 W (current), 270.0 W (default), 270.0 W (max) |
| Thermal Limit | 93.0 蚓 (max), 95.0 蚓 (slowdown), 98.0 蚓 (shutdown) |
| Cores | 5888 |
| ROP Units | 96 |
| TM Units | 368 |
| RayTracing Cores | 46 |
| Tensor Cores | 184 |
| Technology | 8 nm |
| Memory type | GDDR6 (Samsung) |
| Memory size | 8 GB |
| Memory bus width | 256 bits |
| PCI device | bus 38 (0x26), device 0 (0x0), function 0 (0x0) |
| Vendor ID | 0x10DE (0x1458) |
| Model ID | 0x2484 (0x404C) |
| Root device | bus 0 (0x0), device 3 (0x3), function 1 (0x1) |
| Performance Level | Base |
| Core clock | 1500.0 MHz |
| Memory clock | 7001.0 MHz |
| Performance Level | Boost |
| Core clock | 1815.0 MHz |
| Performance Level | Current |
| Core clock | 210.0 MHz |
| Memory clock | 405.0 MHz |
| Driver version | 31.0.15.3623 |
| WDDM Model | 3.1 |
| Win32_VideoController | AdapterRAM = 0xFFF00000 (4293918720) |
| Win32_VideoController | DriverVersion = 31.0.15.3623 |
| Win32_VideoController | DriverDate = 06/08/2023 |
| Monitor 0 | |
| Model | PL3461WQ (Idek Iiyama) |
| ID | IVM7615 |
| Serial | 1171801500839 |
| Manufacturing Date | Week 15, Year 2020 |
| Size | 34.1 inches |
| Max Resolution | 3440 x 1440 @ 75 Hz |
| Horizontal Freq. Range | 217-217 kHz |
| Vertical Freq. Range | 48-144 Hz |
| Max Pixel Clock | 800 MHz |
| Gamma Factor | 2.2 |
| Software | |
| Windows Version | Microsoft Windows 11 (10.0) Home 64-bit (Build 22621) |
| DirectX Version | 12.0 |
