Micro usb cable for Xbox one of controller
233
233
21 Nov 2004
Wishaw
Need to find some replacement micro usb cables for some xbox one pc controllers
only problem I have is none of the ones I’ve tried so far fit
is there a different standard for these controllers or can anyone recommend a slim fit micro usb
They use the standard micro-usb connection, in terms of recommendations then Anker are a good brand but really any micro-usb cable will do the job. I have been using old phone charger cables for mine.
i've found none of the micro usb cables i have fit in the PC specific controllers.
the xbox ones teh connector is flush on the rear the pc ones have to sit into a small square
The only difference between the pc xbox controllers and xbox xbox controllers is the packaging.... what you are probably experiencing is the **** standard that is micro usb.... it needed to die years ago and is one of the most fragile connections on both the male and female side. I you want to be 100% sure however just get the official cable they are easily enough found on most major retailers websites.
EDIT : Also can you post some pictures? or the cables your trying and the port on the controller that they aren't fitting into?
