Hi gents,
Ive been hunting down a super widescreen monitor with 90hz+ refresh and a res approaching 4k for a while now.
SPECS:
ended up buying this monitor through a well known supplier (1k+ rep) on ebay (took a risk, I know!) and am very pleased with it.
I'm sure i'm not the only one who wants something like this and I ain't seen mention of it yet so figure i'd let you know.
I imported this from korea to Ireland essentially.
Ive made a review over at overclock.net for those who are interested. I don't know about rules for linking externally to another board, so i'l avoid for now.
unboxing:
https://youtu.be/Z5SIi2pPjwg
OSD menu options:
https://www.youtube.com/watch?v=tcv-vZ9pjmI
The panelook sheet on this particular panel isn't quite accurate, the 100hz refresh is native out of the box. I overclocked mine to 110hz without issue, though I'm at 105hz day to day. My particular monitor has 0 dead pixels or stuck pixels, but like any monitor, YMMV. Its got an antiglare finish, which suits me to the ground as mine is near a window.
let me know if you have any questions and i'l try to answer
I haven't been able to toy with the freesync much as i'm using a GTX1070. I do have an r9 280x under my bed, but loathe to swap it out
. Another guy over there got freesync range down to 34, ain't messed with it personally.
SPECS:
Brand: Microboard
Model: M340CLZ
Panel maker: Samsung LTM340YP03
Panel Type: a-Si TFT-LCD
Screen Size: 34 inches
Resolution: 3440 x 1440
Inputs: DVI / HDMI 2.0 / DP 1.2
Viewing Angle: 178 degrees
Max Refresh Rate: WQHD 100Hz / WFHD 144Hz
FreeSync Range: 42-100Hz
Pixel Pitch: 0.07725(H) x 0.23175(V)
Frequency: H: 88.86KHz / V: 60Hz-100Hz
Contrast Ratio: 3,000:1
Aspect Ratio: 21:9
Curved ratio: R1800
Response Time:8MS (GTG) / 4MS (OD)
Power Consumption: 60W
Size (includes Stand): 814.98 x 249 x 437.36 mm
Weight(Packing): 10.4 kg
Voltage Free Volt: AC100-240V 50/60HZ
Plug Type: Korea C Type
VESA Mount: Unknown
Microboard website page
Currently shipping from Korea on ebay for $700.
Model: M340CLZ
Aspect Ratio: 21:9
Curved ratio: R1800
VESA Mount: Unknown
unboxing:
OSD menu options:
