Hi all,
Just a quick one,
I have a possible failed hard drive in a Microserver that is using RAID1, it has 2 x 1TB Western digital REDs.
I was getting disk alerts flooding my inbox, then one of the disks dropped out the cluster (disk 2) I have tested both of these by removing disk 2 and booting, it booted in to windows.
Then done the same test with Disk1, it booted. I have run data lifeguard on disk 1 and it seemed to go through fine, took around 2 hours 24 mins to complete, I have started the same on disk 2 but I can already sense there maybe some issues as it takes some time, stops, starts again, so im thinking its picking up or having issues reading/bad sectors.
Issue im having now is that the logical drive is showing as critical and I need to bring a new healthy disk back
There is data on these drives (albiet that is also backed up nightly) but if possible I dont want to loose data
When your bringing disks in and out there is no data loss? I need to bring disk 2 back in to logical drive 1 essentially, or if thats not going to work, create a new logical drive with the data still intack?
In Raid Expert im seeing
Physical drive info
Drive on Port 1 - 1.00 TB
Assigned LD 1-01
1.00 TB
Drive on Port 2 - 1.00 TB
Assigned JBOD
Logical drive is
Assigned Name RAID Level Status Background Activity Capacity
Logical Drive 1 RAID 1 Critical Idle 999.99 GB
JBOD on port 02 (00) JBOD Functional Idle 1000.20 GB
I think what I need to do is delete the logical drive within raid expert and let it rebuild,
Just a quick one,
Physical drive info
Assigned LD 1-01
1.00 TB
Assigned JBOD
Logical drive is
