Hi guys,
I'm building a microserver with ECC memory and Xeon processor. Just not sure which hard-drive setup I should get. I'm not that concerned about drive failure but more concerned with data integrity/correctness.
Currently have 3 setup options:
A) 2 WD Red 2TB drives in Raid1.
B) 1 WB SE 2TB drive
C) 2 WB SE 1TB drives in Raid0.
WD RED: http://www.overclockers.co.uk/showproduct.php?prodid=HD-397-WD&groupid=1657&catid=1660&subcat=1954
WD SE: http://www.overclockers.co.uk/showproduct.php?prodid=HD-445-WD&groupid=1657&catid=1660&subcat=2269
I could go for 2 WB SE drives in Raid1 for the best case but that is at least an extra £70.
Question is does Raid0 incur a higher chance of data error and does Raid1 reduce the chance of data error due to redundancy?
Which case performs the best for data integrity, little care about the drive failure risk.
Hope someone else on here as been in a similar decision and can shine some light on the matter.
Cheers.
Cheers.
