13 Sep 2007 at 22:27 #1 ben16 ben16 Associate Joined 3 Jul 2007 Posts 165 When I load up the computer it POSTS then an message comes up saying: "Intel CPU uCode loading error No IDE Master H.D.D Dectected! Press F1 to Resume" If I press F1 nothing happens. I've tried getting to the BIOS setting but nothing happens.
13 Sep 2007 at 22:29 #2 killer_uk killer_uk Soldato Joined 12 Mar 2003 Posts 4,068 Location OcUK HQ Could we have your full system specs please?
13 Sep 2007 at 22:46 #3 gumbald gumbald Soldato Joined 26 Aug 2006 Posts 9,726 Location 62.156684,-49.781113 What happens if you unplug your hard drive? Or plug in a different hard drive?
13 Sep 2007 at 22:57 #4 ben16 ben16 Associate OP Joined 3 Jul 2007 Posts 165 I've sorted the HDD problem (I set-up RAID0), now just when I turn it on it comes up with a black screen saying: "Intel CPU uCode loading error Press F1 to Resume" Then if I press F1 it just goes to a black screen and nothing happens. I have a Q6600 on a ASUS P5K Deluxe mobo. Edit After about 5 mins it came up with the Vista installation menu. It is VERY slow though. What order should I be booting from?
13 Sep 2007 at 22:58 #5 gumbald gumbald Soldato Joined 26 Aug 2006 Posts 9,726 Location 62.156684,-49.781113 Quick Google suggests a BIOS update
13 Sep 2007 at 22:59 #6 thefishdude thefishdude Associate Joined 8 Oct 2006 Posts 1,672 yeah sounds like needs a bios update to recognise *** quad core
13 Sep 2007 at 23:05 #7 ben16 ben16 Associate OP Joined 3 Jul 2007 Posts 165 O.K I've seen the downloads on their site. Do I get the download under the SATA tab or under the BIOS one. - The latest BIOS is a beta, will this be O.K? How can I install a BIOS update without a floppy disk drive?
13 Sep 2007 at 23:06 #8 gumbald gumbald Soldato Joined 26 Aug 2006 Posts 9,726 Location 62.156684,-49.781113 Does the most recent stable one support Quad? They might have a Windows-based update program.
13 Sep 2007 at 23:13 #9 ben16 ben16 Associate OP Joined 3 Jul 2007 Posts 165 The instructions are here: http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=503&SLanguage=en-us But is doesn't mention anything apart from using a floppy
13 Sep 2007 at 23:16 #10 gumbald gumbald Soldato Joined 26 Aug 2006 Posts 9,726 Location 62.156684,-49.781113 Can you borrow one from another computer? It's the safest way to do it.
13 Sep 2007 at 23:20 #11 Kalpsn2000 Kalpsn2000 Associate Joined 7 Aug 2007 Posts 936 Location London I have just built the rig in my sig and didn't have to update the BIOS. Q6600 on a P5K Deluxe. EDIT I do have the B3 stepping though. It might need the update for the G0 stepping.
13 Sep 2007 at 23:21 #12 gumbald gumbald Soldato Joined 26 Aug 2006 Posts 9,726 Location 62.156684,-49.781113 What revision are you both running?
13 Sep 2007 at 23:25 #13 ThatJoe ThatJoe Associate Joined 18 Aug 2007 Posts 781 Location London, England I have a p5k-e and i had to update the BIOS for my G0 Q6600 to get rid of that error. Go with bios 0503.
13 Sep 2007 at 23:29 #15 ThatJoe ThatJoe Associate Joined 18 Aug 2007 Posts 781 Location London, England If i'm correct the BIOS update is for the G0 Chips. Not the B3s
13 Sep 2007 at 23:30 #16 gumbald gumbald Soldato Joined 26 Aug 2006 Posts 9,726 Location 62.156684,-49.781113 Sounds like an update then OP, find a floppy drive
13 Sep 2007 at 23:34 #17 ThatJoe ThatJoe Associate Joined 18 Aug 2007 Posts 781 Location London, England Or a USB drive, Either will go with EZ Flash.
14 Sep 2007 at 07:37 #18 ben16 ben16 Associate OP Joined 3 Jul 2007 Posts 165 I've managed to install Vista without the BIOS update so I should be able to download it tonight using the BIOS updater on the mobo CD. Thanks for everyone's suggestions
14 Sep 2007 at 14:20 #19 Kalpsn2000 Kalpsn2000 Associate Joined 7 Aug 2007 Posts 936 Location London ben16 said: I've managed to install Vista without the BIOS update so I should be able to download it tonight using the BIOS updater on the mobo CD. Thanks for everyone's suggestions Click to expand... Don't update with the Asus windows updater though as it will most likely fail and kill your board: There have been a number of posts about the posts Asus windows updated failing. Here's one: http://forums.overclockers.co.uk/showthread.php?t=17773316&highlight=bios+update+failed
