- 7 Jan 2007
- Sussex, UK
Hi Total-Game,
I have this cpu cooler currently in my M-ATX build >>> Zalman CNP8000
comapring the dimensions of mine and your artic cooler that didn't fit, it would seem that my zalmans 20mm extra in heigt is going to be a showstopper? Is that right? Would it fit if I didn't run a DVD drive?
EDIT: gah searched the internet but i can't find an intel low profile cpu cooler anywhere.
____________________________________________________________
edit 2:
Ok only cpu cooler i can find that would fit, without buying a new cpu is this one:
In the blurb it says something about only supporting cpu's upto 65W, my e6300 at stock will run ok?
edit 2:
AK-CC044 is a thermally advanced ultra compact and low noise solution for Intel LGA 775 processors. The low profile design makes it a perfect cooler for mini-ITX, HTPC and SFF systems.
Aluminium heatsink with full height copper core and quiet 70x10mm fan ensure high efficiency. High engineered multi directional aluminium heatsink maximizes heat dissipation and provides optimal CPU, motherboard and VRM cooling.
Intel approved pushpins ensure easy installation and reliable retention. AK-CC044 is designed to work with CPU’s up to 65W but greater cooling efficiency can be attained with efficient case airflow. Pre-applied high performance thermal compound ensures clean and easy installation.
Socket type - Intel LGA 775
Cooler dimension - 70 x 70 x 30.9mm
Heatsink dimension - 70 x 70 x 20.9mm
Heatsink material - Aluminium with full height copper core
Fan dimension - 70 x 70 x 10mm
Fan connector - 3-pin (RPM reading)
Fan speed - 2800 RPM
Fan airflow - 14.92CFM (ft/min)
Fan air pressure - 1.67mm H20
Bearing type - Ball bearing
Voltage rating - 12V
Noise level - 23.38 dB(A)
Thermal interface - Pre-applied
Mounting - Push-pins
Weight - 222g
