Mine is bigger than yours =o)
  • Thread starter Thread starter mrk
  • Start date Start date
Tim said:
Messenger Beta and audio properties. 20 processes.
:eek: Do you actually use your computer? :p
Craig321 said:
Hah, Zap's is nothing compared to my Dads.
My Dad idles around 600mb mem used and in use he uses up to 1gb
He's the turbo multi tasker :p
Right now I'm running FileZilla, Task manager (just to look at what mem usage) and 3 tabs in Mozilla (not including background programs) and I have 33 processes 310mb mem taken.
Craig.
Which version of firefox are you using? The normal one or 'your' version :p ?
I use it far too much, I often wonder what its like outside:p
No really, none of the above taskbars have any program that I would find useful. I play CoD2, use MSN and IE6, thats it.
a few things that i use that do not need a systray icon
bluetooth (i use the file transfer wizard from the start menu)
daemon tools (i use the awxDTools plugin so i can right click files to mount them)
steam (always close this when gaming is finished)
outlook (never leave it open)
speedfan (never leave it open)
I claim dibs on SQL Server Service Manager. I write so much T-SQL at the moment I think I'm turning into a DBA :p
Re: UltraMon. Anyone know whether Vista will have better multiple-monitor support? I'd like to dump the prog if possible as I only use it for the second taskbar :)
37 processes running.
arty
I'm going to cry if Vista doesn't have proper multi-mon taskbar support. They've hinted at it before in the 4000-series builds:
But I've not heard anything on the subject since then :(
Caged said:
You realise you can hide the DivX icon in the preferences, and MS Antispy is Windows Defender now and has no tray icon?
I don';t like the new antispy interface so stick with the old style - divx icon reappears after a few days regardless of settings when playing movies...like i said though, it only shows when playing a divx movie.
Trigger said:
How many processes have you all got running then? I have ~36 myself...
Pah, 83 Processes here, though this is my pc @ work so all sorts gets dumped onto it.
Robb
19 processes on a work PC (including excel, word, ff, outlook, putty)
Outlook, power meter (it's a laptop) and audio in systray.
I dont know why i have quicktime running
WLM, Xfire, Steam, Nokia PC Suite, ObjectDock, Fraps, DynDNS Updater, TKC, Daemon Tools, MS AntiSpyware, NOD32, LogMeIn, DU Meter, ATI thingy, Quicktime, Net Limiter, Volume Options [duh], Safely Remove Hardware [for RAID drives]
What it looks like normally -
:p
