Minecraft problem
8 Aug 2009
Swindon :'(
Hi there people. Recently, I tryed accessing the original minecraft in browser on a macbook and accidentally declined the option to enable the plug-in. Every time I now open the window it says to enable the applet yet it never appears. Does anyone have any idea on how to re-open the applet? Or if original minecraft is even compatible with a macbook?
Sorry I am a tech nub but what is the 'cache'? And this is a family computer so is that like the history or search terms?
It's a store of sites you've visited that's used to speed up browsing. For Safari, the empty cache option is in the main menu (the one with file, edit, view, etc.) under Safari.
what plug-in did you decline? was it Java,
Do you have a firewall? cause normally you set manual trusted sites and app?
Edit : sorry read post about the app being safari, but check firewall for trusted apps and sites.
Not really, they're not exactly massive programs and i find both Chrome and Firefox superior to Safari so if anything you'd be doing your dad a favour
Well here is the problem as my Dad actually prefers Safari and he thinks it is a superior browser. Personally I do prefer using Chrome although, I have repeatedly asked my Dad if I could install either. No way of convincing him I'm afraid :p Being a user of all browsers I do believe that Chrome is best but I may just have to stick without Minecraft thanks to my Fathers stubbornness :'( Buying it soon anyway :D
