Mini build.....Onboard GPU......Which CPU / Mobo
2 Dec 2004
Under The Desk, Wales
Guys, I am toying with building a Mini ITX Rig. No Dedicated GPU. Just game now and again and in low settings.
What is the best CPU / Mobo combo with intergrated GPU?
I will be buying a Modular PSU and a small case, maybe a Core 500.I have an SSD.
Plus i will get 8GB ram
It will be used for all types of stuff with the occasional game. Cheers
Intel Core i5-6400 2.70GHz (Skylake) Socket LGA1151 Processor - Retail
Gigabyte GA-Z170N-WIFI Intel Z170 (Socket 1151) DDR4 Mini ITX Motherboard
Be quiet! Pure Power L8 530W '80 Plus Bronze' Modular Power Supply - With 120mm Silent Wing Fan Built in be quiet!
Phanteks Enthoo Evolv ITX Mini-ITX Chassis with Window - Black Phanteks Enthoo Evolv ITX Mini-ITX Chassis with Window - Black
TeamGroup Elite 8GB (2x4GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - Black (TPKD48GM2400HC16DC01)
This a good combo? Decent on chip GPU?
AMD Kaveri A10-7850K 12 Compute Core APU w/ Radeon R7 Graphics (4 CPU + 8 GPU Compute Cores) - Retail
Gigabyte F2A88XN-WIFI AMD A88X (Socket FM2+) DDR3 Mini ITX Motherboard
TeamGroup Elite Black 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD316G1600HC11DC01)
This good? Better than i5 and HD5500?
I would go for I5, especially sdkylake as it's capable of playing games 1080p. Here is a link to igpu that this cpu has: http://www.guru3d.com/articles_pages/core_i5_6600k_processor_review_desktop_skylake,14.html
And if you feel cpu is too slow just buy 960 4gb later on. AMD apu's are there forever there isnt anything you can do to make them run better as cpu performance is way behind intels. Although A10 7850k will give you better performance in games.
He wants to occasionally game, there's no point getting an i5 when he can get an AMD APU for half the price.
So the AMD is a good system? I see people saying that Intel is better but i dont have a clue.
Would i be better off getting the i5 5th gen instead?
What about this spec, would it run on a Pico 160W PSU as the case i like is tiny:
F1CWS Evo Chassis
I will be using an SSD which i have and an external USB DVD drive. No Dedicated GPU as onboard is all i need.
i5 5675 might be worth looking at? GT3e
What are you actually needing to do with the PC?
I'm on an AMD at the moment, for generic use and occasional gaming machine, it works great.
An Intel setup would have course be quicker in demanding applications, but for light gaming, its really not worth the extra cost!
If you were going AMD, it opt for the 7800, rather than the 7850/7870k, due to it being 65w.
I been using Intel for years and just like them. I used to use AMD but since changing to Intel i have never thought of going back.
I understand that thought, the broadwell chip is what I'd buy for an itx setup just now, if budget was high.
The AMD chip is based off years old design, but with fast ram, the strong GPU keeps it relevant. There are some decent FM2+ ITX boards also.
The Skylake Intergrated GPU looks great and the CPU i was looking at is 65W.
I think i should head towards Skylake and save up a bit more!
HD 5500 is faster than HD Graphics 520?
I am leaning towards an Intel Core i5 6400 Skylake
Unsure on that one, horrendous naming conventions from Intel with their graphics.
You'd want the Iris Pro ones only, as the performance is great for integrated!
