Alright guys,
This will be my first home built PC so I'm after advice from some experienced hands. I've been doing research for a little while and have chosen the BitFenix Prodigy-MiniITX to put the components into. I am on a budget of around £600. From the research I've done I can see that it may be better to go down the AMD route for price/performance with my budget. So far I have:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-073-BX
http://www.overclockers.co.uk/showproduct.php?prodid=CP-353-AM
http://www.overclockers.co.uk/showproduct.php?prodid=GX-123-GI
http://www.overclockers.co.uk/showproduct.php?prodid=MB-482-GI
http://www.overclockers.co.uk/showproduct.php?prodid=MY-141-KS
http://www.overclockers.co.uk/showproduct.php?prodid=HD-026-KS
http://www.overclockers.co.uk/showproduct.php?prodid=CD-090-LG
I am looking to move from console gaming to PC gaming. I have a 1TB Western Digital hard drive from a shop bought PC that I'll be able to use in this. Any advice on components or alternative builds with a similar budget that would out perform what I have chosen. If anyone can suggest cooling and a solid psu that would also be handy. Budget could stretch to 700 providing I'm happy to split the buying over two months.
Thanks
Thanks
