hey
so trying to fit an h60 into this case was a really bad idea, it just does not go in, at least not without kinking pipes and risking damaging something. I made the decision to just redo the thermal paste on the Noctua and put everything back how it was.
I've been running it tonight switching between Doom and Rainbow Six with the pc in the unit under the TV where it was before and after a few hours of gaming the only issue I've had is playing Rainbow Six Seige. In Doom the CPU stays in the 70's and only goes up to 80c ish which is perfectly acceptable. if I switch to Rainbow Six it adds another 10c to the CPU temp instantly so it's definitely the game. The weird thing is that the CPU doesn't appear to be under that much more load than when playing Doom so I'm not sure why Rainbow Six causing my CPU to heat up so much.
BTW I agree that my card is probably contributing a lot to the temperature in the case as it's not a blower; it's a 1080ti with traditional fans. I'm keeping a lid on its own temp with software and it has been performing very well so I have no concerns there, but, I do agree that it's probably not helping when trying to keep my CPU temp under control.
Anyway, I'm going to just live with it for now, as the only time the CPU gets too hot so far is with Rainbow Six. Doom it's a good temp, especially considering my set up. If things get too hot playing Rainbow Six then I'll just pull the case out onto the floor, it's no big deal.
I will see how things go and perhaps try the suggestion of flipping the bottom fans round, see if that helps the cpu out a bit.
Thanks all
