Mini-ITX Gaming Build. *Advice*
11 Sep 2008
Northamptonshire
What do you think? the case can only fit a 9" graphics card i do believe, im sure the one there is about that, correct me if im wrong.
The PC-Q08 is being released soon and this can take a dual slot graphics card AFAIK:
http://www.silentpcreview.com/forums/viewtopic.php?t=57370
You will need to get the retail version of the CPU as the OEM version lacks a cooler:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-311-IN
I would go for this PSU instead:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-118-AN&groupid=701&catid=123&subcat=
Since the PSU is the main system exhaust you need to get a good quality one that operate well at higher ambient temperatures. The Antec is made by Seasonic AFAIK.
You can also get SATA DVD rewriter for a few quid more too:
http://www.overclockers.co.uk/showproduct.php?prodid=CD-090-LG&groupid=701&catid=10&subcat=951
http://www.overclockers.co.uk/showproduct.php?prodid=CD-099-SA&groupid=701&catid=10&subcat=951
thanks a lot,
liking the sound of the dual slot on the new case which means i can choose a better graphics card :) when does the case get released?
edit: Sorry didnt see it on the ocuk site my bad
