Hi guys,
I have the need to build a small yet powerful PC for the front room. I've done some research and this is what I've come up with:
CPU - Intel Pentium K Anniversary G3258 Socket LGA1150 Processor - Retail
SSD - Crucial M500 240GB SATA 6Gb/s Solid State Hard Drive - (CT240M500SSD1)
RAM - TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD38G1600HC11DC01)
MOBO - Asus H81I-Plus Intel H81 (Socket 1150) DDR3 Mini ITX Motherboard
CASE - Cooler Master Elite 130 Mini ITX Case - Black
PSU - Corsair Builder Series CX 430w Modular '80 Plus Bronze' Power Supply (CP-9020058-UK)
OD - LG GH24NSB0 24x DVD±RW SATA ReWriter (Black) - OEM
What are your opinions?
I don't believe I need a wifi card because the PC will be close enough to the router to hardwire.
Also, I may want to dabble in overclocking the CPU and have read that the H series motherboards can overclock if the BIOS is updated??
If this is possible could you recommend me a aftermarket CPU cooler that would fit in the case?
Thanks
Thanks
