Mini ITX?
1 Oct 2014
Northern Ireland
Hi all so currently have a lot of parts bought from this list but whats your views?
Anything that wont go together with this build?
Main question too was will this build run at normal temps and not over heat or am i missing something?
Bitfenix prodigy MITX Case
Corsair 600w PSU
Team Group 8GB Ram
MSI Z97I Motherboard
Corsair H60 Liquid CPU Cooler
GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" 4096MB GDDR5 PCI-Express Graphics Card
Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail
Kingston 120GB SSD For My OS
Western Digital Caviar Blue 1TB For general storage
The build will be for gaming, a lot of illustrating and photoshop, and watching movies and tv shows.
Thanks!!
Heat wise you'll be fine. The Prodigy is designed as an MITX and has good airflow that way (same can't be said for MATX version). Considering you're going for MITX is size important? The handles make it quite a large case.
I personally would have picked a larger SSD - it's always surprising how fast a drive fills up. And with Photoshop et al the extra scratch space/temp files is always useful.
Are you planning to overclock? If not, I'd reduce the processor and double the RAM to 16G, again for Photoshop (and having a couple of illustrations open at once).
As ote1 says this won't overheat in the case. I haven't used the H60 so can't comment if that will cool everything, but it'd be fine if air cooled.
taking on board your suggestions i see now that more ram would be a lot better. I bought 8gb ram already but i think i shall return it and get the 16gb kit instead.
i shall not be overclocking so yes thats a good point as well. perhaps this processor would be a better job and save me around £30
http://www.overclockers.co.uk/showproduct.php?prodid=CP-533-IN&groupid=701&catid=6&subcat=567
ssd wise what about this
http://www.overclockers.co.uk/showproduct.php?prodid=HD-037-CR&tool=3
also i am hearing good things about that version of galax from ocuk.
Is there a different version of GPu that would be excellant for less money or would the 970 be thee gpu to go for?
thanks for the replys guys was thinking i wasnt gonna get any reply lol
Oh one other thing i also had a spare external hdd that i never used and i pulled out the hdd from its case. it is a western digital caviar green 2tb hdd. would it be good for playing games off of and storage or is the caviar green from western digital a crappy version of hdd?
i did buy the bitfenix and yes the handles made the case around 2 inchs taller on both ends. but it isnt a big issue as it fits nicely under my desk
