The Nehemiah M10000 has a hardware mpeg2 decoder built in that should help with SOME dvd playback stuff. I have one of these boards and it was fine with most vid files and dvd's i chucked at it, plus you can run it fanless if you stick a Zalman blue NB Heatsink on the cpu
so it can play most divx files no problem?
The cheapo (50 quid) mini itx intel atom D945GCLF board is all you need for sd xvid and divx etc.
Use the freeware media portal and you have an ultra cheap HTPC.
I tried it and had no problems streaming and playing xvids. I used an ide to CF adaptor and ran with xp and media portal on a 4gb cf. All xvids where streamed from a NAS.
It was quite a nice little system. The fans a little noisy, but I removed it an glued on a 80mm.
However I dumped the system as it wasnt up to playback of HD 1080p.
Great feedback - what are you using for HD?
Yeah, had one of those for the past 3 months too - except mine's running an e7200. Handles 1080p with no problems @ only 30% cpu usage. The X4500HD onboard video is incredibly capable.Infact I just finished another HTPC last night with the intention of using it only for playback of SD and HD.
Again mini itx based.
The cpu is probably overkill for even 1080p.
So far everything seems to be running ok, using media portal. I will post some pics of the finished system shortly
