Mining PSU question
18 Oct 2002
Riding my bike
I'm building a mining rig and need to clairfy a point.
I have molex powered PCIe risers and GPUs requiring 1 8pin PCIe connection (1070s).
My plan was to have a single cable doing each riser and a single cable doing each GPU.
But the PSUs specs weren't clear and when it said 8 molex what it meant was 4 per cable from the modular PSU.
Now the last thing I want to do is to overload any cables. So is the following safe (each line represents a modular cable from the PSU):
PSU cable 1-----------Molex to riser 1------------Molex to riser 2 (3rd and 4th molex connector not used)
PSU cable 2-----------Molex to riser 3------------Molex to riser 4 (3rd and 4th molex connector not used)
PSU cable 3-----------8pin PCIe to GPU 1------------8pin PCIe to GPU 2
PSU cable 4-----------8pin PCIe to GPU 3------------8pin PCIe to GPU 4
+1
I Would like to know this myself.
I am currently building a rig with 3 x 1070ti and getting the correct PSU/config has proven the hardest part to get clarity on.
So at present I have a Corsair 850w and plan to do this:
PSU cable 1-----------Molex to riser 1-----------------Molex to riser 2
PSU cable 2-----------Molex to riser 3-----------------Molex to Motherboard
PSU cable 3-----------8pin PCIe to GPU 1-------------8pin PCIe to GPU 2
I have ended up setting it up as follows:
PSU 1 cable 1-----------Molex to MoBo------------Molex to Mobo (3rd and 4th molex connector not used, MobO needs molex connections AsRock H110 BTC Pro)
PSU 1 cable 1-----------Molex to riser 1------------Molex to riser 2 (3rd and 4th molex connector not used)
PSU 1 cable 2-----------8pin PCIe to riser 3------------8pin PCIe to riser 4
PSU 1 cable 3-----------8pin PCIe to GPU 1------------8pin PCIe to GPU 2
PSU 1 cable 4-----------8pin PCIe to GPU 3------------8pin PCIe to GPU 4
PSU 2 cable 1-----------8pin PCIe to riser 5------------8pin PCIe to riser 6
PSU 2 cable 2-----------8pin PCIe to riser 7------------8pin PCIe to riser 8
PSU 2 cable 3-----------8pin PCIe to GPU 5------------8pin PCIe to GPU 6
PSU 2 cable 4-----------8pin PCIe to GPU 7------------8pin PCIe to GPU 8
Al working fine PSUs are connected together using the OcUK dual PSU adaptor that has two ATX-24 connectors with a pair of wires to cause the slave PSU to start up when the master one does..
