mixed speed fans in push pull
3 Jul 2007
Rochdale/whitworth
hi i have a 44mm 360 rad with 3 lian li TL LCD fans i was thinking of doing a push pull on the rad but of course i do not want the LCD ones on the bottom because it is point less and a waste of money if i cant see the LCD. i was thinking of getting the TL fans for the bottom of the rad as pull and keeping my TL LCD on top as push. The difference in fans air flow/presser will not be a problem due to the rad being in the middle ? do you think it will work as intended and will not damage the weaker fan
I have done it loads of times
Just used whatever fans I had laying around
At the time
Never caused me an issue If they were mismatched
Though I would probably say
You don't need push and pull on a 44mm rad
At the time
thanks sounds good.
maybe i do not need it but the tl lcd fan are not really a high presser fan and with it being a thick rad push/pull sound like a good idea plus it will look good lol
thanks sounds good.
It probably won't make much
Temperature difference on a 44mm
Usually once it's 60mm
I do push and pull
But it won't hurt either
And of course if it looks good
Doesn't hurt
I do push and pull
after 25mins running both fur-mark with cinebench together my cpu is around 77c (max 80c) and gpu is at 64c (max 66c )with a normal fan carve if I max the fans from the start the temps probably be a little lower
Ive always found that push/pull makes very little difference. So i just dont bother anymore. Ive always got 2 x 360 rads, so always cool anyway.
Btw are you from Rochdale or whitworth? I can usually tell by shoes, whitworth people have bigger shoes for that extra toe :D
I'm technically from Bury and Whitworth is in rochdale I'm sure you mean Bacup they have the extra toe haha
Infact yeah your right it's classified as rossendale even though its 10--15mins away from rochdale
