Mixing Memory - Slot Order?
1 Nov 2004
When filling 4 slots with 2 different kits like above does it make any difference what order you place them in the slots , should you alternate?
Shouldn't hugely matter as they will all run at the lowest speed but normally you put them in the matching dual channel slots e.g. 1&3, 2&4
I couldn't alternate them between the dual channel slots because of the size of the Vengeance heatinks with my HR-02 cooler but it still worked.
