mixing programs
Permabanned
28 Oct 2006
Bournemouth
hi, im looking for programs similar to that of music 2000ps1 (but for pc)
i want it to have premade backing tracks etc. and also options to import sound files, im not in the know of this sort of thing so any well known and easy to use programs would be much appreciated
thnx
If you are looking for a simpler sequencer with premade loops and samples, then Ejay is indeed for you.
If you actually want to mix on pc, something like Traktor or Atomixmp3 would be better suited.
Demented Ferret said:
Premade tracks? Importing stuff? Looks like eJay is what you're looking for. It's about as simple as you can get and I presume it's similar to Music 2001.
thank yu, i think i remeber a program with a asimilar name to that, probzbly is the same one im thinking of.
Thanks all
