- 3 Mar 2009
My sisters car, since she bought it, has always required quite a long time of cranking before the engine finally fires into action, with some assistance of pumping the throttle. Once up and running it seems absolutely fine, even better than my old Ghia I had which would stall now and then with air con on (doesn't in this one).
We (Me) have tried a few things to see if it would fix it, I have replaced all serviceable parts, cleaned the IAC and put a new gasket in, only ran with BP fuel and have put it through about 3 tank fills with Redex included. All pipes and hoses inspected and securely attached, but nothing seems to help the problem.
It happens pretty much any time you start the car, except for immediately after stopping the engine and firing it back up. With the hot weather recently, its been considerably worse, left out in the heat for 8 or so hours, the car takes about 6-7 seconds before it fires up (the starter seems good, always going fast), with the engine "grumbling" quite a bit which is sorted by again pushing the throttle. When it has these long cranks after the car has been sitting for a while, a big cloud of white smoke comes out the exhaust, but stops immediately after and no further smoke seen while driving.
Not quite sure where to go with it next, I'm thinking possibly fuel pump related or something to do with the fuel, but don't have anything to go on. (I believe the previous owner actually had the fuel pump replaced about a year or 2 ago). No CEL either.
Any ideas where to look next ? I was considering new HT leads or coil-pack, but I don't want to throw money at it without somehow verifying they are bad first, which I don't know how to do
