Hi There
Figured this was the best place to post about storage and the like ! my dad has a maserati 4200 Gransport and inside it has cd player with a MMC Slot. While out shopping we checked loads of places but they all said they didnt stock them anymore.
Ive found loads on the bay , the micro ones which isnt the one he wants ( alltho it looks like it has a connector to make it full sized ) and then theres the normal one that looks the same as a SD card.
Is this the correct car ? is there only 2 variations of MMC card
Many Thanks
Sam
Many Thanks
Sam
