Help... Trying to install a P6T motherboard into an Antec 900 case - Now, I've had issues where the screws aren't biting into the brass fittings, but I've sort of got round that by using slightly different screws that were provided...
However, now I've unpacked the Noctua NH-U12P, and it is instructing me to fix the back plate behind the mobo... So... I've just taken the motherboard /out/ again... But I want to make sure (with anyone who has experience of these) - I can only assume that the piece that sits on the underside of the motherboard is non conductive? Can't really tell what it's made of. - Also I assume it just sits under the motherboard so the components ontop just grab onto it? Doesn't appear to be any fixings for securing it to the case under the motherboard.
Been a while since I've built something, so this is whole new territory for me.
Thanks in advance for any help you can offer.
