Ok... here goes nothing, so this will be my first ever attempt at any kind of modding, and as it'll probably fail miserably I've put it in here for now and not in the project logs.
I'll paint you a word picture...
I currently have an Antec 300 (rig in sig) with 5 HDDs in it...
As you can see space is quite limited on the HDDs and also inside the case, with only one free 3.5 bay. So I'll need to get a new HDD (Samsung F3 2TB most likely) however my motherboard has no spare SATA ports apart from an eSATA on the I/O panel. So I'll either have to utilise the eSATA port or buy a SATA PCI card. I don't really want to fill up my case with a final HDD... So i was trying to think of an alternate... and happened to glance at my desk and see a couple of dismantled 360s and...
...I'll put some of the HDDs in the 360 case, and if I can manage it I'll put a DVD Drive in it too (as the PC being under the desk is annoying to get to the DVD drive, and seeing as this will probably be on my desk anyway it'll be a lot easier to use the CD drive). It will free up space and should help airflow in the case aswell. It's going to be a lot harder/complicated than I'd originally realised, and there are probably much simpler solutions, but to hell with it... I've never tried anything like this before, I'll give it a go!
My plan will hopefully go something like this;
So, It'll hold 3 HDDs and a DVD drive. I'll use the 360s fans for cooling and add others if I need to after testing temperatures. I'll Need to take SATA, IDE (if I use my current DVD Drive) and power from my PC to the 360...
Hopefully more to come and ongoing pictures of the build...
Watch this space
Watch this space
