Modding an AIO with a different radiator
20 May 2026
London
I have a Formd t1 case and the current 15mm fan+ 25mm fan under a Be Quiet Silent Loop 3 just isn't working for my ears. The 15mm nocutas are too annoying under load, about 1100rpm, and I have tried just about every other slim fan with the same conclusion.
I am thinking of replacing the radiator with a 20mm alphacool radiator to fit a fullsized fan and want to know anyone else's experience with modding AIOs, any handy tips?.
As far as I can tell the only nonstandard thing top be wary of is the different sized tubing.
Saw that on reddit. You just need to find right fittings to you aio hoses https://i.~ibb.co~/GQ6Bgmn1/Screenshot-20260612-125308-Chrome.jpg
really will depend
how the hoses attach
and what size the attachments are
got 3 old swiftech units on a shelf here
dead easy with those aio as they take
standard g 1/4 fittings
and standard 10/16mm tubing
definitely doable
but depending on the aio
it may not look great if that's an issue
as may need to use jubilee clips if
an awkward size of tube and pump fittings
