Hi,
I bought a Netgear ADSL2 modem router. I unplugged all the cables from my old netgear router and then plugged the cables into my new router. All the lights came on expect the internet light.
you need to put you internet details in, ring you isp to get them, you then need to enter your router setting find the internet setting and put them in save, reboot all will be good
You need to enter your adsl username and password into the router config, which on yours should be on http://192.168.0.1 (router login admin=admin, password=password).
Well youll need to use the UN/PW you were supplied with for that router. usually its is "admin" by default or "Administrator" and it might use a password printed on a sticker somewhere.
To be honest though if you check your details from your ISP they will probably have sent you a letter with the details on before at some point
The login details for the router should be in the manual. Which ISP are you using? If you don't know the ADSL login details, you'll need to phone them and ask for them.
