I tried Spec Ops for the 1st time yesterday and did the training mission as the 1st one. Any hints for completing that in under 35 seconds? I have barely done it in 45 seconds. I use the default weapons, is that where I am going wrong or do I just need to be faster in general?
rp2000
Use 2 pistols, the M9 and Desert Eagle, start with whichever you like, work your way through, one bullet, one kill. Once you get inside the building, shoot the guy behind the civ in front of you, and to the right line up the 2 tango's in a row and shoot with one bullet to get both. This will increase your accurace to above 100%.
As you go upstairs switch gun, knife the target, clear out the upper level, trying to use one bullet on each target.
Jump down, but as you jump reload, you should finish reloading as you land, and as you do start popping off!
The last 2 guys before the exit, if you're lucky they will be lined up for a 1 bullet kill for both.
And leg it to the end!
You should get an accuracy bonus of around 4-5 seconds, and more if you went over 100%. I dont think its physically possible to actually run through and get everyone in under 30 seconds, however my time was about 34, with 5.3 seconds knocked off for accuracy. And thats how ye do it
Hope that helps.
