Modifying OcUK
ok im really confused as to what I have to do to get this working. I've installed greasemonkey and I've created the usercontent file based on the code in the first post. I've also installed the extension.
At the moment the forums are the different colour - but I'm not sure where I need to go to change where the images are?
fini
aye, same here fini...can't seem to get rid of the images :(
that greasemonkey php thing is just giving me a white background with white text too
Bump because I created an SVN repository for the extension and I'm going to start working on it again now that I have more time :)
Code:
svn co http://svn.robm.me.uk/ocukbb/trunk/
Just source. Run build.bat to build the XPI as well as a directory that you can use with Firefox's dynamic extension loading. To dynamically load the extension, create a text file called
in your profile/extensions directory, which should look be:
Code:
%appdata%\Mozilla\Firefox\Profiles\[b]some string of letters[/b]\extensions
In it, simply put the full path to the build directory that the build script generates (in my case, C:\firefox\ocuk\build). When you start Firefox, it'll load the extension; simply restart Firefox whenever you update your source from the repository.
rob, can't you make it so that it doesn't break Firefox if you have the ocuk forum extension installed?
I'd like to use both, but it just wont have it as they both use "OcUK" in the toolbar.
Why install both if they both do the same thing :confused: If you just want a menu, use the menu extension, if you want the rest install this.
meh, just thought it would be easier than having people wonder whats going on when it completely breaks FireFox.
I do see your point, im not stupid :( :p :D
right i have put the text into the ccs file userChrome.css file, restarted firefox and nothing changes.
Any thoughts?
i really do need to get more sleep and stop playing bf2 at night
thanks
Edit: working now lol. dam plug-ins for FF grrrrrr cant get the buttons to change
White with all images adblocked = office mode.
'spose this saves the admins doing any work on other skins :p
Nah it's fine :)
Here you go:
Code:
@-moz-document domain(forums.overclockers.co.uk) {
	** OcUK colour scheme changer
	** By Rob Miller
	* { color:#000 !important; }
	textarea, input { background:#ddd !important; }
	body, .page, .thead, .tfoot, .alt2, .alt2Active, .panel { background-color: #fff !important; }
	.alt1, .alt1Active, .panelsurround, .vbmenu_option { background-color: #fff !important; }
	.alt2 { background:#dfdfdf !important; }
	.vbmenu_control, .vbmenu_control *, .vbmenu_hilite, .vbmenu_hilite *, .tcat, .tcat * { background-color: #006598 !important; color:#fff !important; }
	.vbmenu_popup { border: 1px solid #ccc !important; }
Nice work. This zombie is still going :)
What would I do with opera then mate? Or should I bite the bullet and join the firefox masses?
