Hey, I just got my new keyboard, a Logitech K340. It's brilliant, just the volume control is a little annoying but I think it's a windows problem. Basically when you hold FN and tap either volume key, the increments are too small to make a big difference, and when you press and hold there is a big lag in between it moving the first increment, and then scrolling the slider up or down.
I've spent a good while searching for an app, and I just thought I'd ask here, anyone know how to either remove the lag/wait or increase the increment?
