Modsticks Pro Xbox 360 Buttons
17 May 2004
Thought I'd share some pictures of my new buttons, did a search and couldn't see any posts/threads about Modsticks stuff.
This may be one of those more money then sense purchases but I'm really happy with them. The actual pressing of the buttons is much nicer, they have a little more height as I'm am using all the spacers. Also the button travel is lower so requires less force to push. What I really like is the start and back buttons, the buttons are higher then the originals so are much easier to use. The originals were recessed a lot and difficult to activate.
Also I think they look brilliant. I will be buying the triggers and the sticks next month so will post some pictures of those fitted also.
And here are some pictures:
ModSticks Buttons by MIKEYMC1, on Flickr
The buttons are two parts, the lower part is a cup and the buttons sits in it. They are held in by two rubber O-rings, which means you can twist them around. Can't say I read the buttons while playing so thought it amusing to put them upside down.
Nice but this is where it's at...
I want something that will make my sticks move just as easy as the ps3 pad sticks do and i can't be arsed with a wired razer
Well the Modsticks sticks having thinner shafts so you get a wider movement on the sticks. Not sure about the feel. Guess I'll see if I can let you know next month.
i remember checking that site out a while back, infact im sure it was you who put a link up in another thread that introduced me to that site.
im having trouble finding out how a scuff controller will solve my issue, maybe its me but i cant find anywhere a feature that will lessen the tension of the 360 sticks to the same degree of the ps3 sticks on the site. i hope im missing something because i would love to have this sorted.
the 360 sticks look good, i assume they stop the wandering problem when the analogue sticks get worn?
i wonder if my speedfreek would fit on them...
