modular psu sockets
25 Apr 2014
I recently purchased an EVGA nex750G and won't be using a lot of the sockets on it. I was wondering if there was such thing as a blanking set for it so I can hide the empty sockets. I'm not a massive fan of the bright red connectors in my blue and black rig :p
I know you can get cavity blanking seals for minifit jr but I doubt if you'd get them in black. At best these, even if they were dyed black, would cover the majority of the connector but would leave some red visible.
There are rubber seals available I believe that would fit over the connector but the connector on your PSU is flush mounted so that wouldn't work. Good luck finding them though.
What about a black 8 way connector without the terminals fitted?
