- 5 Aug 2006
- Derbyshire
Hi, I have airbourne and when trying to install it I am having problems
The game auto runs, I select install, enter serial and click next and then a box appears headed 'microsoft visual c++ 2005', the box has a progress bar (same as the progress bar you get when copying a file) which fills up then emtpies and closes the install. no error messages, nothing.
Specs as sig and Im using XP at the mo.
Any help at all ??
.The game auto runs, I select install, enter serial and click next and then a box appears headed 'microsoft visual c++ 2005', the box has a progress bar (same as the progress bar you get when copying a file) which fills up then emtpies and closes the install. no error messages, nothing.
Any help at all ??
thanks
any ideas why MOH airbourne won't install anyone??
